Author Topic: Front fork/fender brace  (Read 4545 times)
BigRed
« on: June 26, 2008, 08:03:54 AM »
I'm looking for the part # for the fork brace (heavy steal bracket/brace) that goes between the forks and under the front fender. If anyone knows the part name or #, i would be grateful.  I don't have one on my bike and i have read things about ppl having problems without it and some people don't.
also is this consider your tech section or am i posting in the wrong section
Offline kghost
Re: Front fork/fender brace
« Reply #1 on: June 26, 2008, 08:34:08 AM »
Should be in another section as this is for Tricks and Tips.....
I dunno that they have a part number for that brace...its part of the fender Part number.
Course you just drill them off if you want no front fender.
Parts wanted might be the section for this but one of our excellent mods will prolly move it.
Stranger in a strange land
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: June 26, 2008, 08:37:09 AM »
Generally this section is for sharing tips and tricks with others, generally tech questions get posted in the SOHC/4 Bikes section.
I don't think the fender bracket is available as a separate part number.  You could eBay a junk fender of the appropriate year for your forks and drill the rivets out to get the brace, or if you're using an early 750 setup, take a look here:
http://forums.sohc4.net/index.php?topic=32575.msg337081#msg337081
cheers
mystic_1
- John Augustus Shedd
BigRed
« Reply #3 on: June 26, 2008, 09:43:32 AM »
thnx alot
BigRed
« Reply #4 on: June 26, 2008, 09:53:22 AM »
just found the whole assembly in chrome for a buck lol...but still putting the fiberglass piece on, the chrome won't match. :)
BigRed
« Reply #5 on: June 26, 2008, 10:41:24 AM »
Found out they sell fork braces. teleflex fork brace or a tarozzi fork brace.  Everything i've read about these is they are great.
« Reply #6 on: June 26, 2008, 12:01:40 PM »
Do they have one for the K0 to K2 models? I think you'll find that because the tops of the fork legs are lower than the top of the tire, conventional fork braces won't work. I doubt that teleflex and tarozzi have a brace for these bikes. I know SuperBrace never did. You could be looking at later models?
That's why we use the honda fender brace or build one. Which BTW to those involved in the build-a-brace, wow! I've never seen that design and I thought I'd seen it all. Great work.
BigRed
« Reply #7 on: June 26, 2008, 12:15:15 PM »
they make one, looks like a mini fender but its a 100 bucks. so ill just go with the used fender
« Reply #8 on: June 26, 2008, 12:39:44 PM »
That's interesting! Post a link or picture if you get the chance. Sounds like a...fender brace.
I'm going to try a ZL900 steel fender on my Phaedrus project, (K2 "custom") its fairly substantial but short. I think Kaw may have used it to double as a fork brace on the ZL. It's for an 18" wheel, and I have downsized the wheel on my project.
I'll also use a custom made tweak bar right under the triple clamps. I'll be posting a pic of it this weekend.
