Author Topic: Is my frame bent? Handlebars turn too far (photos)  (Read 1287 times)
Offline fmctm1sw
« on: June 28, 2008, 12:11:45 PM »
Been working with this 400F off and on since last summer.  I bought another set of handlebars off ebay since I reached the conclusion mine were bent.  Got the handlebars and..  same thing  :(  What I am now realizing is that my front wheel turns way further to the right than it does the left.  Look at the photos.  It's harder to see in the photo but use the #1 and #4 pipe as a frame of reference.  Am I screwed?  Is the frame bent or something?  Something told me it might have been laid down at some point but it didn't appear to be anything serious enough to bend the frame or anything.  What do you make of this?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Leino
  • Not much of an
  • in drag racing since 2005
Re: Is my frame bent? Handlebars turn too far (photos)
« Reply #1 on: June 28, 2008, 12:14:10 PM »
Sounds like a steering stopper problem.
Offline fmctm1sw
« Reply #2 on: June 28, 2008, 12:19:16 PM »
At first glance that did look a little off center (it may be just wishful thinking though).  I just don't know how it could have gotten off center.  It's hard to see very well.  I'll try to get a closer look...
*edit*  You may have hit the nail on the head.  The stopper is "mushroomed" on the one side from the handlebars being slammed to one side.  Huh... and I thought that little bump on the lower steering clamp always busted.  Looks like this one smashed the steering stop.  It is probably bent too...  Thanks... :)
« Last Edit: June 28, 2008, 12:43:43 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Leino
  • Not much of an
« Reply #3 on: June 28, 2008, 12:49:19 PM »
No worries mate.  ;)
Offline fmctm1sw
Steering stop issues. Handlebars turn too far (photos)
« Reply #4 on: July 04, 2008, 07:27:08 AM »
Getting back to this...  How would you approach fixing it?  The stop definately looks of center if you look straight down on.  Should I just try to grind it off and start over?  or just try to coax it back into shape?
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #5 on: July 04, 2008, 10:00:34 AM »
On my CB350F, one of the stops on the frame had been drilled through and tapped.  With a screw and lock nut it is now an adjustable stop.  I don't know if that is stock since the PO had mod'd the 350 into a cafe back in the late '70's.  I don't have a pic right now.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
