Author Topic: 5/8 Hayabusa Brake Master Cylinder  (Read 2140 times)
Offline tank410
« on: June 28, 2008, 06:12:55 PM »
I am planing to do the dual disc conversion on my CB500. I have just bought a set of 550 forks form Honda!. I had a caliper and GL1000 master cylinder give to me when I bought the bike. But after close inspection the reservoir is cracked at the base. So my question is will a Hayabusa's master cylinder work?
CB500
Offline Wayne Meuir
Re: 5/8 Hayabusa Brake Master Cylinder
« Reply #1 on: June 28, 2008, 06:33:34 PM »
It'll probably work, but you may not have a mirror mount on it if the Busa has the mirrors mounted on the fairing.
I used a M/C of a Naked SV650 on my Waterbuffalo and it works great and has the mirror mount hole.
Wayne
« Last Edit: June 28, 2008, 08:01:28 PM by Wayne Meuir »
No problems that winning the lottery wouldn't fix
Offline alltherightpills
« Reply #2 on: June 28, 2008, 06:44:24 PM »
Are you asking if the ratio between the caliper piston and the mc bore will be okay?
vintagebrake.com/mastercylinder.htm has a chart that will show you what size mc to use depending on how big your caliper pistons are and how many you have.
I recently used this chart to get a new mc off of ebay.  I didn't get into the perfect ratio range that he suggests, but I got close and my brakes feel awesome, and they work really well now too.
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Offline tank410
« Reply #3 on: June 29, 2008, 08:36:39 AM »
I am not worried about the mirror mount I running bar end mirrors
So if I am reading the chart right with 2 38mm pistons I need a 11mm master cylinder.
CB500
« Reply #4 on: June 29, 2008, 08:50:26 AM »
that will be 7/16.
I used stock 750 m/c with good results..
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #5 on: June 29, 2008, 05:20:46 PM »
Don't know your budget, but the NISSIN MC (14mm) is REAL NICE.....$129.00  super smooth...
here is my setup..dual 750 disks on my 550.
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
