Hi-well done in your choice of project. Some tips from a first timer; Take as many photos as you can of the strip-down and try to store them on your PC chronologically so when you are reassembling you'll benefit from knowing which part goes in first. Store every single bit, bob, nut, washer, bolt, screw etc in a resealable transparent plastic bag and label clearly with a marker. The parts that are too big to fit in a bag you can thread a cable tie thru any hole etc and attach the label to the cable tie.
Don't set yourself a deadline because then the project will become a chore rather than a hobby. Even if it takes a couple of years, so what? At least the job will be a good'un and something you can be proud of.
I have met so many experienced and skilled people on this first project, that have minuscule workshops squirrelled away all over the country that have helped or given me advice or made further suggestions on how to proceed. Powder coaters, vapour blasters, polishers, engine technicians, wheel builders and so on.
The cherry on the cake is a forum like this one where loads of guy/gals are only too willing to help.
Enjoy, there's only a load of bollix on the telly anyway.
