Author Topic: CB750 Gearbox Bearings  (Read 3612 times)
Offline 77honda
« on: July 01, 2008, 05:50:02 PM »
Anyone know where I can get new bearings for the gearbox, namely
6008 NR
6304 NR
6205 NR
Local bearing suppliers here can get these BUT the snap ring groove is way
too thin only 1mm where as stock bearings have groove approx 2mm wide.
Thanks, Mike
CB750 K7
Offline mrosso
  • The before picture.
Re: CB750 Gearbox Bearings
« Reply #1 on: March 27, 2009, 01:19:22 PM »
I can find standard skf bearings that match all but the snap ring width too. If you order bearings with "NR" instead of just "N" suffix, they come with a snap ring already installed in the narrow groove. I'm not sure if that would work, though. Here's a pic:
Anyone know if you have to have the 2mm snap rings or can you just use the small ones that come with aftermarket bearings?
I'm doing an engine rebuild too. Motor and transmission.
« Reply #2 on: March 27, 2009, 01:59:29 PM »
Generally, a bearing supplier (one who does more than just selling bearings) can cut a groove to match any existing bearing.
Barring that, you can chuck a bearing into a drill and use a Dremel tool and cutoff wheel to make your own groove.
Two of the gearbox bearings are listed as "high speed" bearings (the ones on the mainshaft). These should be the "extra clearance" bearings, available in bearing catalogs, but on special order, usually. These have an extra .0002" to .0004" clearance on the balls and races, to accomodate extra heat and, in the case of the 750 engine, case mount misalignments when under heavy acceleation loads. Using a standard bearing in those places will reduce engine output and make shifting stiffer.
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #3 on: March 27, 2009, 02:17:06 PM »
The grooves need to be widened to the 2mm. I suggest that you get a quote from a machinist to have them widened. Give him an original bearing as well as the new bearing so that he can see which side of the groove needs to be machined/ground.
Pat
Regards
Pat from Australia
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #4 on: March 27, 2009, 02:53:22 PM »
I had a shop grind the snap ring groove into a bearing, the price was shocking!  :o
Get a quote first...
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
« Reply #5 on: March 27, 2009, 10:50:40 PM »
Wow, what did they charge you? It used to be a $5 adder on a $5 bearing...
« Reply #6 on: March 28, 2009, 01:08:27 AM »
Cant you just get the Honda parts?
Offline mrosso
« Reply #7 on: March 28, 2009, 07:58:44 AM »
Some, but others are discontinued.
« Reply #8 on: March 28, 2009, 08:47:10 AM »
Specifically, the last time I tried, the "High Speed" and grooved bearings were NLA from Honda.
I found my research notes: the "C3" bearing clearance is the one that matches Honda's "High Speed" designation. This style has internal clearance of 33um (about .0008") nominal. A normal bearing has about .0004" internal clearance, according to the SKF/NTN catalogs.
Offline mystic_1
  • 1970 CB750K
- John Augustus Shedd
« Reply #10 on: March 28, 2009, 09:02:25 AM »
Yamiya has what you need:
http://www.yamiya750e.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=bearing
mystic_1
That's terrific, Mystic!
I'm afraid to see the prices, but may have to get a set myself. I have some young ones (12k miles) from Soos, but haven't had my bike apart to install them, yet. Maybe I'll get a new set, if I can afford them.
It's cool they also have the rear wheel "bearing plug", too. These get so beat up by corrosion and removals over the years.
