Author Topic: Front end "bouncing"  (Read 2034 times)
NE550
« on: July 03, 2008, 09:10:14 PM »
I'm having trouble with my front end.  I replaced the fork springs and it still bounces.  If I let go of the bars it shimmies back and forth.  Tire is balanced.  Does anyone know what else I should check?
Thanks, Matt
Offline 750K2
  • new rider with an old bike
Re: Front end "bouncing"
« Reply #1 on: July 04, 2008, 04:57:09 AM »
check your stem head bearings for loosness and wear.  then your front rim for true.  check your spoke tension.  get your front rim/tire balanced if necessary.
« Reply #2 on: July 04, 2008, 05:28:23 AM »
Thanks, Matt
+1 from 750K2. Too loose or too tight on the steering head bearings, and/or worn. Also, maybe too heavy on the fork oil or too much fork oil will cause them to lock up and not absorb the finer bumps translating into a bounce. You changed your springs, did you change the oil? Also, when you change springs they may have more mass than the stock springs, meaning that if you use the same amount of oil, there will be too much oil.
Modern day fork set up protocol is to measure down from the top to the oil level of the old set up, then use that measurement for the new set up., rather than measure the number of cc's. That will accommodate for the extra bulk of the aftemarket spring. If you're using a stock spring, no prob here. But experiment with the weight of the oil and the amount.
Offline chrislib
« Reply #3 on: July 04, 2008, 06:16:03 AM »
Another vote for stem bearings, also swingarm bushings,fork oil level, wheel trueness. I had the same bounce at 35mph and up, those things were all wrong on my bike, fixed it and now it`s very nice.
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
Offline tbpmusic
« Reply #4 on: July 04, 2008, 06:49:26 AM »
Wobble = Check your swingarm bushings.
ALL problems with "geometry" are manifested in the front end - because that's the part that has least resistance, it's designed to move freely.
So problems in the back will nearly always result in a front end wobble or other wierdness.
bill2
Bill Lane
« Reply #5 on: July 06, 2008, 09:49:12 AM »
Worn tires can make it do that, and too light a fork oil.
I would never NEVER rely on measuring what is in the fork as a guide to capacity, besides it is very time consuming. Use the recommeded amount, if you feel the springs are altering volume, compensate accordingly.. I doubt you will  need less oil if you put bigger springs in for the reasons most do..
« Reply #6 on: July 06, 2008, 12:05:13 PM »
If by NEVER you mean you prefer not to, I can see it. However it is now the accepted way of doing things. This tool helps, http://www.motionpro.com/motorcycle/partno/08-0121/
For instance unless you do a complete fork teardown and wipedown you won't get all the old oil out and if you just pour in X amount you have too much.
« Reply #7 on: July 06, 2008, 09:49:13 PM »
I may be not understanding..
 What you wrote sounded like it measures the level of the oil, but the link shows a pump or vacumn extractor..
My thinking still is that when you are servicing forks, (moreso ones that are leaking).. the old amount is not a reliable guage as to recommended capacity..
 So are you saying you dont drain out of the bottom? and stuff stays there??
« Reply #8 on: July 07, 2008, 09:08:21 AM »
It is a combination measuring stick and extractor, for sucking out excess oil.
I would agree the level is not a good gauge for the amount that should be in the fork unless you already know the appropriate measuring spot for that model, and for the CB750 I don't know. I've only done complete teardowns recently.
When I was riding my NT650 hawk at trackdays a few years ago, the suspension gurus said to ALWAYS measure, never drain and fill. That fork I had setup for me and they measured it as the correct height is well known in those circles. I had them add cartreidge emulators and Progressive springs (which use heavier wire and tighter coils) so the mass in the tube was greater and to simply fill with the recommended amount would result in overfill and poor performance.
And finally, yes if one simply drains out the drain hole, even pumping, there is a large amount of oil that will stick to the parts. So drain and fill will almost surely result in overfill. Only upon teardown and cleaning should one use the recommended amount to refill. Anything else is a best guess and may not be equal on both sides.
If one already has the fork back together, the tool can be used first to see that the levels are equal in both tubes, and then experiment in small increments.
This thread furthers the argument and gets rather heated, so I respect both sides, but advance the measuring argument. http://www.t595.net/messageboard/thread/Fork-oil/23868.aspx
The tool can be replicated with a syringe and plastic tubing.
Offline scondon
  • Mmmm......tasty bugs
« Reply #9 on: July 07, 2008, 09:32:08 AM »
From what I remember:
Rebuild capacity from K3?- K8 and 75-78 F.
145-155cc
Refill after draining
115-125cc
*Measure level from top of fork tube with shocks fully compressed and springs removed
6"
* I'll check back on this once the coffee kicks in ;)
« Reply #10 on: July 07, 2008, 10:50:33 AM »
145-155cc
115-125cc
6"
That's a great start! I think the K0-K2 forks held more, like 225cc after teardown. Mesaurement unknown to me, but I'm rebuilding mine from teardown in the next month or so and will post.
Offline scondon
« Reply #11 on: July 07, 2008, 11:09:40 AM »
145-155cc
115-125cc
6"
   I've never worked on the early forks but 220-230cc at rebuild is correct. I think 155-165cc after draining.
