Author Topic: How do I remove the heads? (76 CB550)  (Read 2588 times)
Offline scartail
« on: July 05, 2008, 04:52:04 PM »
I've removed 12 nuts, and two bolts. The head won't budge. I looked for a pry spot, but didn't find one. So, I better ask first.
Any advice?
PS: the engine is still mounted in the frame, if that's relevent.
'89 Hawk GT, newly acquired, daily beater...
'76 CB550, was my daily beater... my cafe project...
'72 Yamaha R5, newly acquired project... donated to my buddy...
'67 Suzuki T20, still working on her too... Currently in pieces...
Offline scartail
Re: How do I remove the heads? (76 CB550)
« Reply #1 on: July 05, 2008, 10:09:41 PM »
Anyone?
The manual simply says to lift up. There's got to be a trick.
Offline chopstar500
  • King of the Nighttime World
« Reply #2 on: July 05, 2008, 11:38:34 PM »
Did you verify that you've got all the bolts/fasteners per the parts/diagram. I can't say for ceratin without looking at the fiche to tell you exactly how many bolts there is. Mine was a bit of a pisser - be careful not to bust any fins.
Completed Project "Four Pack" - My 1971 CB500 KO - Now For Sale - email me for more info!
Offline fastbroshi
  • Puppet
« Reply #3 on: July 05, 2008, 11:47:02 PM »
+1, double check your fasteners.  Those breather covers on the ends hold two bolts going vertically, as well as the ones under the breather cover.  There are two pry points on the ends, not quite on the corners if I remember right.  Is your motor very dirty?  The muck may be hiding them.
  If you're sure you've got them all give it couple of good wacks straight on the sides, carefully with not too much force, and then try to pry.
  And the head/barrels will come out w/o taking the motor out of the frame.
Just call me Timmaaaaay!!!
« Reply #4 on: July 06, 2008, 03:55:51 AM »
12 nuts and washers
2 10mm headed bolts
CAM CHAIN TENSIONER LOCATING BOLT
Offline scartail
« Reply #5 on: July 06, 2008, 07:10:36 AM »
12 nuts and washers
2 10mm headed bolts
That's my count.
The heads are very clean. When taking off the valve cover, I notice there was a lot of rust on the alignment pins.
I don't see any pry spots though. In the manual, it mentions pry spots to remove the cylinders.
Doesn't hurt to study it again.
Thanks everyone, I'll keep looking.
Offline Porscheguy912
  • I'm a Big Shot Ninja.
  • It's MR. Moustache To you SIR!
« Reply #6 on: July 06, 2008, 10:45:26 AM »
May i Propose a silly idea?
did you remove the cam chain? ;) ;) ;)
I dont mean to say that you wouldnt know to remove it, just making sure!
I had a 550 but i never took the head off.
Current: 1978 CB750F3
Past: 1974 CB550K
Offline scartail
« Reply #7 on: July 06, 2008, 11:13:36 AM »
I found a tab/pry spot, that fastbroshi spoke up. I was timid about prying on it, b/c I didn't to damage anything. Then I broke out a crowbar, and went to town. I use some 2X4 to support. I had bent one of the fins slightly, earlier, and didn't want to do that again. So, they're off.
Thanks everyone.
In summary (just so this thread could benefit others),
-12 nuts and washer + 2 bolts need to be removed.
-Pry pads are on the backside of head, sort of under the No 1 and 4 intake runners. Runners were removed for convenience.
-Since the Pry pads are the head only, use something to support the prybar. Don't pry against the fins. I used a piece of 2X4, longside up.
-Lastly, don't be timid about it. Put your weight behind. But dont' hurt yourself neither.
