Author Topic: What is this washer made of?  (Read 1651 times)
Offline James
« on: July 06, 2008, 05:47:35 AM »
I have a feeling its aluminium can anyone else confirm?
http://www.cmsnl.com/honda-cb550k3-four-european-direct-sales_model14672/partslist/E01.html
Part number:14     Honda part number:90485001000  WASHER, 6.5M/M
Thanks
Gort, Klatuu Baratta Nic-DOH!
rhos1355
Re: What is this washer made of?
« Reply #1 on: July 06, 2008, 05:56:23 AM »
Thanks
James, from the short time i've been working on my restoration project I've come to the conclusion that most out of stock items have been discontinued by Honda for the simple reason they are relatively easy to replace by pattern parts or other sources. So I can only surmise the washer you're looking for is a bog standard washer.
PS is the quote at the end of your post Cumbrian?
Offline James
« Reply #2 on: July 06, 2008, 06:00:45 AM »
rhos,
if it was cumbrian I would've pronounced the full stop as "eh"  :D
No its a line from the film 'The Day the Earth Stood Still' (one of my favorite films) but with a bit of 'The Simpsons' on the end
J.
Offline dpen
« Reply #3 on: July 06, 2008, 08:05:12 AM »
eh? on the end of a sentence? - must be related to Queenslanders
Offline 333
  • Time for change
« Reply #4 on: July 06, 2008, 08:54:44 AM »
What does the old one look and feel like?  Typically, aluminum and copper washers are used as "crush" washers to make a "hard" seal.  The drain plug on the crankcase is a crush washer.  The banjo bolts on the brake system use crush washers.  I can't tell what the washer in the picture does, or if it needs to "seal" anything.  I hope I've given you enough information to help.
And I recognized the quotes.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
« Reply #5 on: July 06, 2008, 09:07:10 AM »
6.6mm =1/4 in
Sounds like it is easy to make, alum or copper both work for crush washers..
« Reply #6 on: July 06, 2008, 09:07:26 AM »
Yes its allumunium but a THICK copper one will do or one of what i know as "Dowty Sealing Washers" that have a rubber insert and normally available from hydraulic people.
PS get extras as there is another one at the top off the cam chain tensioner
troppo
« Reply #7 on: July 07, 2008, 12:33:56 AM »
Nothing wrong with Queenslanders, eh? ;)
Offline Hush
« Reply #8 on: July 07, 2008, 12:44:42 AM »
Note for US citizens: Queensland is a small island of the West coast of New Zealand. ;D
Offline James
« Reply #9 on: July 07, 2008, 01:24:33 AM »
Thanks guys, for some reason the old ones went missing, theres none left at the parts places I shop at but I'll probably get some at the local engineer supplier.
Offline 333
  • Time for change
« Reply #10 on: July 07, 2008, 07:41:39 AM »
But, what does it "seal"?  I don't recognize the application as anything that needs sealing.  Is it some sort of passageway for oil?  My background is in parts, not wrenching, so it's not so obvious to me.
Offline dpen
« Reply #11 on: July 07, 2008, 07:55:43 AM »
quick note to our US cousins - Queenslanders are the Australian version of the Amish..........living a century or so behind the rest of us
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #12 on: July 07, 2008, 08:16:31 AM »
That washer doesn't seal anything.  If you have oil coming out of there, you've got bigger problems.
Looks like its just a washer, there to lift the bracket that the valve cover end-caps bolt to.  Not sure why it needs to be there, but a standard washer should do the trick.  I suppose that bracket can twist/turn on maintenance, so having a washer keeps it from wearing on the valve cover.  Who knows.
But, again, it isn't sealing anything.  The end-caps have two pins with o-rings that go into the shafts where your rocker arm shafts go in and out of.  They are prone to leaking, so replace the o-rings while you're there.  They seal the oil in the valve train.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline mark
« Reply #13 on: July 07, 2008, 09:06:17 AM »
As previously established, it's a thick aluminum washer, can be replaced with copper or one of those rubber insert washers.(neat idea, btw)
What does it seal? That bolt goes into that puddle of oil at the end of the cam - outside the bearing where the oil feed comes squirting out. There's probably more oil in that area than there is splashing the chain tensioner - where the Honda folks also felt a need for the same washer.
Happy trails.
F you mark...... F you.
Offline 333
  • Time for change
« Reply #14 on: July 07, 2008, 09:12:40 AM »
That picture tells way more than the parts diagram.
« Reply #15 on: July 07, 2008, 09:57:53 PM »
That bolt also blocks the end of the drilled oil way up from the base gasket forcing oil along the oil pasages to feed the cam brgs
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #16 on: July 08, 2008, 12:20:24 AM »
it definitely seals the stud hole from leaking oil everywhere from the cam case. i fitted one of those covers to a 650 engine to make it look more like a 550, and until i got the fit right it leaked from that hole. there's no pressure (other that crankcase pressure), but there is oil behind it.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
