Author Topic: Transmission bearings; to be replaced or not to be replaced?  (Read 848 times)
Offline skishyishy
That is the question.  All other components of the transmission seem fine and the bearings themselves don't appear to have any visible problems.  They spin with what appears a minimum of friction, but they are from a bike I bought not running.
Anyone have an opinion on this?  I saw a lot of talk on the post about some difficulty finding the correct replacement bearings.  I am primarily talking about the 6204, 6203 bearings;  especially the countershaft bearing
thanks
martino1972
Re: Transmission bearings; to be replaced or not to be replaced?
« Reply #1 on: July 06, 2008, 01:14:30 PM »
6204 and 6203 are a common bearing
in doubt,replace
Offline Bodi
« Reply #2 on: July 06, 2008, 03:19:34 PM »
The bearings with grooves for set rings are not standard parts and a stock bearing won't work. A bearing supply shop should be able to get the groove ground in if you give them measurements or a sample, but Honda may have them is stock for less than a stock bearing plus grinding.
I've rarely changed these bearings, they run in oil and have a pretty much infinite life.
martino1972
« Reply #3 on: July 06, 2008, 06:51:42 PM »
 :D,didnt know they had grooves..sorry,i just saw the numbers,and they are common..
