Author Topic: 1976 CB750A anybody have pictures?  (Read 2839 times)
Offline javahut
    • Pleasant View Glass Works
« on: July 06, 2008, 02:26:32 PM »
I have a 1976 CB750A, it came as a sock, sorta, project, the motor was out of the frame there were parts all over, in boxes and baskets, got most of it back together, what I need is a good, clear, well lit picture of the right side foot peg area.  Where it mounts to the motor mount bolt.
It is different from all other "A"s in the way in mounts, have a 77, not the same, so I need to know what or how the footpeg goes on.
According to the microfiche of parts, it is the same footpeg as 77 and 78, but there must be something missing on the 76 that does not show on the later years, there is an aluminum part attached to the parking brake assembly that is NOT on the '76 that IS on the 77.
Also, if the footpeg is different and anyone has one, would be interested in acquiring one.
Thanks in advance....I'll watch the post or my bio IS filled out for further contact if you can help.
Offline Clyde
Re: 1976 CB750A anybody have pictures?
« Reply #1 on: July 06, 2008, 05:22:01 PM »
The footpegs are very different to the 77 and 78 models.
I have sent you some pics of mine and a friends 76A.
Have a look at the parts manuals on CMS or WesternHills Honda. The differences are substantial.
Regds
Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline javahut
« Reply #2 on: July 06, 2008, 05:57:21 PM »
Thank you, got your pictures and sent a reply, will check out your recommendations, looked at a couple of parts fiche's and found no differences
Offline Clyde
« Reply #3 on: July 06, 2008, 07:24:15 PM »
I checked the WesternHills site and they have a good break up of the rear brake pedal with no aluminium plate on the 76.
The fiche/parts book for the 76 is dedicated to that model whereas the 77/78 have a combined fiche as they are similar, except for the comstar wheels and paintwork
The 76 has different footpegs similar to the 76F, but without the aluminium plates
76 has a 4-1 exhaust/77and 78 have a 4-2 exhaust
77/78 have a speed pickup in the speedo, wiring plug is different in the pilot box
77/78 have different handlebar switches as they run the wires outside the handle bars
77/78 carbs are different with different floats and float heights.
Handle bar clamps are different
77/78 seats are different
77/78 use 630 chain
etc
Clyde
SOHC4 #1909
Offline javahut
« Reply #4 on: July 07, 2008, 06:11:31 AM »
Clyde, your assitance is terrific, but I have the bike running and looking pretty good, other than the paint is not original, everything else is good, except that darn footpeg, only thing I need, mounts similar to earlier years, but the bar is longer, I believe...from frame to the actual footpeg.
Offline Clyde
SOHC4 #1909
Offline javahut
