Author Topic: Float Height  (Read 4877 times)
Offline rchrdms
  • Honda CL350 Twin '72
    • Richard F Meese
Float Height
« on: July 06, 2008, 02:52:24 PM »
Hi,
I'm rebuilding my carbs and the manual lists a bunch of different float heights for my model(1972 CL 350 Twin).
My engine number is CL350E-4040351. This number is not on the chart. The float heights are 19mm, 21mm, and 26mm, depending on engine number.
I have twin Keihin 722A carburetor.
The engine numbers listed are 1055165 to 1065278 (21mm);
1065279(26mm);
and prior to 1045165 (19mm).
Thanks.
Offline tonycb650
Re: Float Height
« Reply #1 on: July 06, 2008, 07:20:37 PM »
I would probably check your engine #s again and see if your  4 could possibly be a 1. Some old bikes can have some corrosion there making it hard to see.
80cb650c 80 cm400
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Float Height
« Reply #2 on: July 06, 2008, 09:41:53 PM »
I might be able to help, here is what I came up with:
CL350K4
Sell Date: 1972-73
Rel Date: 02/01/72
Product Code: 345 (Middle number of Honda part numbers)
Frame number: CL350-4000001
Engine number: CL350E-4000001
So the engine number does match up as a `72 K4 model.
Honda CB,CL,SL Carburetor Specifications:
Carb model 350A
Float level 19.mm
Std main jet #60 primary #115 secondary
Std slow jet #38
Idle mixture screw initial setting 3/4 turns from closed
Idle speed 1200rpm.
Carb model 3B & 3C
Float level 21.mm
Std main jet #70 primary #110 secondary
Std slow jet #35
Idle mixture screw initial setting 1 turn from closed
Idle speed 1200rpm
Carb model 3D, 722A, 726A, 728A
Float level 26.mm
Std main jet #68 primary (722A,726A) #70 primary (3D,728A)
Secondary #70 (3D,728A), #105 (3D, 722A, 726A)
Std slow jet#35
Idle mixture screw initial setting:
3/4 turn from closed (3D)
1 1/8 turns from closed (722A, 726A, 728A)
Idle speed 1200rpm.
NGK: B 8ES/ ND: W24ES Gap .028-.032in
Ign point gap .012-.016in
Ign Advance "F" 10º BTDC
Max advance 37º- 43º BTDC
Advance starts @ 1300rpm
Max advance 3900rpm
Dwell angle 105º (on 2 cylinder scale)
Condenser capacity 0.22 - 0.26 MFD
So according to this the 722A carbs are set at 26mm. ;)
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline rchrdms
    • Richard F Meese
Re: Float Height
« Reply #3 on: July 07, 2008, 04:03:35 PM »
Wow, that's super useful! Thanks a lot. The other info may come in handy too.
thanks,
Richard
