Author Topic: are carbs different from year to year?  (Read 791 times)
Offline uwjberg
« on: July 06, 2008, 05:58:19 PM »
so i just purchased my first SOHC - a '75 CB750F. the carbs are way gummed up, and i've managed to break the float pin tower-thingy that's a part of the carb body (don't ask). i need another carb, but i need to know if a carb from another year 750 will work - ie, carbs from a '74 will be the same as the ones on my '75. any ideas? i may pick up another set and use the best parts to make a complete set of four.
thanks,
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: are carbs different from year to year?
« Reply #1 on: July 06, 2008, 06:01:30 PM »
They can be.  Go to the main SOHC site (Website button at top) and click on the CB750 link.  Look in the specs section for each year.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline uwjberg
« Reply #2 on: July 06, 2008, 06:08:24 PM »
i tried that - it just lists the jet size, etc. not the carb model itself. unless i'm missing something?
Offline uwjberg
« Reply #3 on: July 06, 2008, 06:11:23 PM »
so i found one that i'm looking at, and the picture matches the carbs that i have. should i be ok? there are'nt different sizes of the keihin carbs on the 750's, are there?
Offline 333
  • Time for change
« Reply #4 on: July 06, 2008, 06:27:26 PM »
There are model numbers on the carbs, so matching them up isn't too difficult.  But the jet sizes can be different depending on what bike(or year of bike) the carbs are off of.  The sizes are on the side of each jet.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #5 on: July 06, 2008, 07:40:50 PM »
You can have that peice welded back on.
1977 CB750
Offline uwjberg
« Reply #6 on: July 06, 2008, 08:59:53 PM »
hmm. i guess i didn't think of that. what about jb weld or quicksteel, i wonder?
