Author Topic: shooting ducks  (Read 1370 times)
74550pa
shooting ducks
« on: July 08, 2008, 02:12:44 PM »
my 74 cb550 has a problem I can't figure out. I reset the valves,checked the timing,and rebalanced the carbs. it runs great until I get into high gear,then it starts popping and has no power. I have no clue as to what is going on any help would be greatly appreciated
martino1972
Re: shooting ducks
« Reply #1 on: July 08, 2008, 02:32:19 PM »
when you get in higher gears or higher rpm's??
Re: shooting ducks
« Reply #2 on: July 08, 2008, 04:28:35 PM »
air filter details?  New?
Spark plug deposit description?
Does the bike have all stock components?
Re: shooting ducks
« Reply #3 on: July 08, 2008, 06:07:46 PM »
Raise the slide needles one notch.
adpage
Re: shooting ducks
« Reply #4 on: July 08, 2008, 06:13:22 PM »
+1 on raising the needle clips.  You are running lean.  i had the same issue with my 750 k4.
Offline Hush
Re: shooting ducks
« Reply #5 on: July 08, 2008, 06:14:43 PM »
And check carb to head boots for leaks by spraying a little silicone on to them when bike is running to see if there is a change in idle revs.
Offline DONZIE
Re: shooting ducks
« Reply #6 on: July 08, 2008, 08:27:16 PM »
Check the vent on your gas cap
Offline rbmgf7
  • 2>4
Re: shooting ducks
« Reply #7 on: July 09, 2008, 01:40:37 PM »
what do you mean by "popping"? when you throttle, does it hesitate and sound like it's sucking in a lot of air? you're probably still runnig lean. if you're running stock main jets with those pods, you may need to take it up a size or two.
and what do you mean by your plugs have a lot of color to them? are they white, tan, or black? flat black or gloss black?
and what's so hard about shooting ducks? maybe you need to work on your spread, lol.
