Author Topic: Sleeve boring  (Read 730 times)
Offline ekim98
Sleeve boring
« on: July 09, 2008, 01:47:37 PM »
How much over can you bore the stock cylinder sleeves on a k8 750, and still be safe. I've never torn my engine apart, so here's another question, can you replace the rod bearings on the big end. I looked and can't find a part number, just the main crank bearing replacement number.
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline Clyde
Re: Sleeve boring
« Reply #1 on: July 09, 2008, 08:24:05 PM »
General consensus on the largest size that you can go to boring a stock sleeve is 65mm which gives 836cc. 61mm is stock.
If you are looking for connecting rod bearing part numbers have a look at this site. It is for a F1 but they are the same engine as the K7/K8, except for the drive shaft and output sprocket which has been beefed up and uses a 630 chain
http://members.lycos.nl/hondaf1/cb750f1_partslist.htm
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
