Author Topic: ground clearance???????  (Read 795 times)
martino1972
« on: July 09, 2008, 01:55:58 PM »
hey,...
im in the process of lowering my cb650 in the back..
im going bobber style and im replacing  the rear shocks with welded chain...
in an attempt to get it as low as i can,i noticed my 4-1 exhaust is getting pretty close to the ground..
its running kinda centre under the bike ,so for cornering it wont matter,but do any of you know what clearance i atleast need from lowest point under the bike to the ground..??
im asking this with welder gun in my hand,ready to weld the chain onto the swing arm..
Offline scondon
  • Mmmm......tasty bugs
Re: ground clearance???????
« Reply #1 on: July 09, 2008, 02:45:35 PM »
 As much clearance as the size of the object you intend to run over ;)  Seriously, if you're making a hardtail out of your bike then the front forks are the only dampening,besides the air in your tires, right?
Bottom out your front forks and add an inch?
martino1972
« Reply #2 on: July 09, 2008, 03:18:37 PM »
well,i just went with it,and me sitting on the bike,kinda pushing in the front im left with close to 2 inches ground clearance....
its starting to look pretty cool(my opinion) cant wait to roll her out of the shop..
i got a tread in the project section,i will update that with pictures as soon as im done,should be today or tommorow..
