Author Topic: 1978 supersport  (Read 1627 times)
Offline 2wheels
1978 supersport
« on: July 10, 2008, 01:01:53 PM »
I've never driven this year or model before.
When driving down the road, really any speed,  30 to 50 MPH, the bike seems to go side to side a little.  Like it's looking for it's centre line.  Not much, certainly not a speed wobble, but enough that I noticed it.
It has a new front tire and just had the steering head bearing replaced.
Is this normal, if not any ideas.
Thanks.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
eldar
Re: 1978 supersport
« Reply #1 on: July 10, 2008, 01:06:37 PM »
Could be a number of things.
The tire may not be mounted true. The rim could be warped a little. Front to rear alignment may be off.
Hell, the roads around here get these little grooves but into them after they have been poured and it can make the bike weave like you are describing.
Uneven shock preload or unequal fluid height can cause this.
Re: 1978 supersport
« Reply #2 on: July 10, 2008, 01:47:05 PM »
Are the steering head bearings smooth?
Are you using ribbed tread pattern tires?
Are the tires worn square? (lots of center wear)
keener
Re: 1978 supersport
« Reply #3 on: July 10, 2008, 01:48:01 PM »
Ive experienced the same thing on my 77 CB550K, I have nothing yet for you but ill let you know
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
Re: 1978 supersport
« Reply #4 on: July 10, 2008, 02:02:15 PM »
What's your tire pressure?
1977 CB750
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
Re: 1978 supersport
« Reply #5 on: July 10, 2008, 02:26:08 PM »
swingarm bushings????????? just my thoughts good luck
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline 2wheels
Re: 1978 supersport
« Reply #6 on: July 11, 2008, 06:04:19 AM »
Great responces.
Not likely the roads, but now that you mention it, it does feel very much like riding on those ribbed concrete surfaces.
The front to rear alignment is a possibility.
I must check the front shock fluid, also a possibility.
The head bearings are new and feel OK, to me anyway.
The new front tire has 2 jagged ribs.
The rear tire is a little flat in the middle, I've probably had worse on other bikes, but ??
Tire pressure is good.
The swing arm, I'm not sure about this.  Another one to check out.
I've got some work to do.
