Author Topic: Stupid CB 750 clutch question  (Read 1113 times)
Offline dramsell
« on: July 10, 2008, 05:00:34 PM »
If the clutch lifter plate was installed crooked (meaning the bolts that you use to attach the new springs were uneven making the lifter plate skewed), what would that do to the bike?
Would it still shift as normal?  When the next cover was put on would that move everything into place?
Dave
Offline Patrick
Re: Stupid CB 750 clutch question
« Reply #1 on: July 10, 2008, 06:27:23 PM »
Having never done it - and until now not even considering whether it was possible - I cannot predict what it would do. However, I seriously doubt the side cover would move everything back into place. If you took your clutch apart and it wouldn't work when you put it back together, I would be inclined to do it again.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #2 on: July 10, 2008, 09:49:04 PM »
One of the ears of the lifter plate will crack (off) forcing the plates together.  or against the clutch inner or outer drum.  It will lock up the clutch lever so you won't be able to engage/disengage the clutch.
Offline dramsell
« Reply #3 on: July 11, 2008, 06:20:28 AM »
Ok.  Now that I have more time and my space back, I will go back in and straighten that out.
Do you think I could reuse the gasket, seeing as it has only been about a month?
Dave
Offline Tower
« Reply #4 on: July 11, 2008, 09:36:23 AM »
Probably reusable, if you oiled it first.  But I wouldn't count on it otherwise.
