Author Topic: converting wire gauge numbers to metric dimensions.  (Read 2161 times)
Offline hymodyne
« on: September 01, 2005, 01:46:41 PM »
I'm looking at super small drill bits at the hardware store, and they are sold by their wire gauge size. How do I convert these numbers to MM's? Specifically, How do I select the proper gauge measurement to match .40 to .45 MM?
hym
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: converting wire gauge numbers to metric dimensions.
« Reply #1 on: September 01, 2005, 02:00:58 PM »
Try somewhere like this:
www.roymech.co.uk/Useful_Tables/Wire.htm
So 0.416mm = 27 guage,  0.457mm = 26 guage
« Last Edit: September 01, 2005, 02:05:56 PM by SteveD CB500F »
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline Bodi
« Reply #2 on: September 01, 2005, 07:24:33 PM »
Are you sure they are wire gauges?
Normal American twist drills come in 3 ranges; fractional - generally available from 1/64 inch to very large in 1/64th increments, number drills from #80 (smallest) to #1 (largest), and letter drills A (smallest) to Z (largest). Number drills start really small and go to just under 1/4 inch then the letter drills go up from there to roughly 10mm.
The numbers are not wire gauge sizes.
There's a decent list of sizes here http://shopswarf.orcon.net.nz/drills.html but I'd do the metric conversion myself, the inch measurements shown are accurate.
Offline Paul
« Reply #3 on: September 02, 2005, 01:31:10 AM »
0.40mm = 0.0157" = Drill No.78
1/64" = 0.0156" = Closest fractional drill to .40mm
0.42mm = 0.0165" = Drill No. N/A
0.45mm = 0.0177" = Drill No.77
Letters start from 5.94mm and up
I know all this from memory  :P
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
