Author Topic: smooth throttle  (Read 1423 times)
Offline bert96
  • past ride
smooth throttle
« on: July 11, 2008, 06:35:45 AM »
My throttle on my 750 is hard,i alway find it hard since i have the bike,all my other bikes
was not that hard.
Is it just me or you find it hard too ???
some of you ever did something about that ???
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
troppo
Re: smooth throttle
« Reply #1 on: July 11, 2008, 06:39:14 AM »
could be you have dry cables mate.
Honda says a little oil down then does the trick, but i think that will merely hold dust and grit.
Try a little graphite powder down the cables, might do wonders.
Could be the way the cables are routed, check to make sure there are no kinks or tight bends in them too.
Cheers
Troppo
Offline .RJ
  • homebase in your airspace
Re: smooth throttle
« Reply #2 on: July 11, 2008, 06:40:51 AM »
was not that hard.
Its the throttle spring.  Its very, very stiff.
Why?  I have no idea.  None of my other CB's (350 and 2 400's) have been like that.
I'd like to fit a 'lighter' throttle spring but havent turned up much at mcmaster or the hardware stores.
Offline bert96
  • past ride
Re: smooth throttle
« Reply #3 on: July 11, 2008, 06:41:02 AM »
you don't have this problem? your's is sooth?
Offline DRam
Re: smooth throttle
« Reply #4 on: July 11, 2008, 07:59:39 AM »
The throttle on my '79 CB650 was extremely hard to turn.  I ended up trying to unwinding the throttle return spring until it held against part of the carburetor.  Not a perfect solution as I have to snap the throttle shut to get complet closure, but at least my wrist doesn't cramp up trying to hold the throttle open.
