Author Topic: want to see 11 inch shock on bike picture  (Read 7038 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
Re: want to see 11 inch shock on bike picture
« Reply #25 on: July 18, 2008, 09:41:57 AM »
also by the way proteal your bikes are the shhhhhhhhhhhhhhut my mouth...the made me forget about harleys as far as the only bike that was cool, when I was looking for my first bike and thought that my 650 was just a phase. so now my wallet (new baby girl) cant afford a harley and the best part about it is now your bikes and lots of other bikes on here ....I never really want one. The honda fours are the best....but I would like one of those ugly ass buells just cause they are so ugly and it doesnt seem like anyone rides them.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #26 on: July 18, 2008, 11:36:00 AM »
PROTEAL You lowered the front two from the looks of it huh....I am debating if I should do that or not...once I get the rear shocks I guess I will check the look and see if I want to lower the front....or if the handling seems bad.
ALL of my bikes get lowered as much as possibile while still being able to have a good ride.
Both my old CB750 and the current CB450 got lowered around 2'' up front. The ride is def. alittle "harder", but it is def. liveable. No need to lower the rear and not lower the front while u are at it...
  • stupid gloripope
« Reply #27 on: July 18, 2008, 01:13:45 PM »
your guys bottom out.....I am not a road racer by any means I take it pretty easy as I like to relax on the bike....just want to be ready if it bottoms out....I have the rear pegs off for ever so they wont hit.
Offline chrislib
« Reply #28 on: July 18, 2008, 01:26:40 PM »
I havent bottomed mine out yet, I weigh 165-ish.
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
Offline ProTeal55
  • Est1968.com
« Reply #29 on: July 18, 2008, 01:29:45 PM »
A great once in awhile I bottom out the shocks on the CB450 with my 200lbs. ass on it.
But overall for how much I ride it all is well...
diggz_82
« Reply #30 on: July 27, 2008, 11:15:41 PM »
ProTeal55, great looking bikes!
but how did you lower the front, just cut the springs? also what dual disc conversion is on the 750? thanks
  • stupid gloripope
« Reply #31 on: July 28, 2008, 01:08:57 PM »
sort of getting freaked out a little like when I go into a turn there is going to be a huge difference guess I will just have to take here easy after I install them. I have only been riding for 2 years ...but damn I love the lowered look.
Offline Cannibal
« Reply #32 on: July 28, 2008, 07:37:04 PM »
Here's my (far from done) 750 with 11" shocks from Cycle Recycle:
And no, that's not pink (previous owner painted it) its burgundy.
  • stupid gloripope
« Reply #33 on: August 04, 2008, 07:49:35 AM »
I want to put them on and check out the looks without lowering the forks and see how bad it handles with the changed geometry of just lowering the rear.
Offline drackett_19
  • '75 cb550K
« Reply #34 on: August 04, 2008, 09:38:16 AM »
Here's a shot of some shorty shocks on my 550. I didn;t think the handling characteristics changed that much...
You can just slide the forks up thru the triple trees to drop the front end some too.
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
« Reply #35 on: August 04, 2008, 09:46:42 AM »
Any problems riding 2 up with 11's?
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Offline goon 1492
  • Sucka Repellant
« Reply #36 on: August 06, 2008, 06:34:45 AM »
riding 2 up is a question I had too, and also I think I remember 754 mentioning in another thread that lowering the rear will change the geometry on the steering in your favor, meaning it decreased the truning radius but in turn would increase handling characteristics.........I think..... correct me if I am wrong. :-\
  • stupid gloripope
« Reply #37 on: August 07, 2008, 08:28:21 AM »
anyone know what size washer they bought used for the bottom clamp...how many etc.
Offline Frankenkit
  • Industrial Strength
« Reply #38 on: December 08, 2008, 08:28:57 AM »
Figured I'd post here, because here I've actually seen a discussion of shorty shocks and handling characteristics, but also the handling results of leaving the front 'taller' vs lowering it.
I suspect 9/10 of the difference of handling would come from the difference in rake/trail, but not sure if it would qualify as 'better' or just 'different'.  I thought someone mentioned (but I will stand corrected) it improves cornering at-speed, but makes low-speed cornering a little worse?
How does the lowered CG factor in?
I'm inseam challenged and seriously considering this to lower the CG, because both of MickeyX's bikes have a significantly lower CG... and while one is probably 100# heavier, it somehow feels 100x more stable, too.  I just want to know if I want to slide my fork up thru the tripletree an inch or so, as well, just to even it out a little?
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #39 on: December 08, 2008, 11:14:15 AM »
Lowering the rear (or adding longer forks for that matter) will make the bike more stable in a straight line, but will slow your inital turn-in meaning that you have to be more deliberate when entering corners.  Lowering the front or raising the rear will have the opposite effect, it won't track as nicely in a straight line, but will feel more flickable.
If your bike is too tall, but you like the way it rides now just run the shorter shocks and slide the fork tubes up.
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
Offline Frankenkit
« Reply #40 on: December 08, 2008, 11:26:04 AM »
If I've got the bike at the lowest setting on the stock shocks, which allows me to juuuust flat-foot it (standing, tippy-toes sitting)  how far would I want to lower my fork tubes thru the triple-trees?  I'd think maybe an inch, but I'm not sure.  Right now they're even with the end of the tube, so the cap on the end is all that sticks up.  It feels like a beast to turn right now, especially at low speeds.
1973 CL350- Lola?
Stuff for sale
Offline ProTeal55
  • Est1968.com
« Reply #41 on: December 08, 2008, 11:30:15 AM »
You could always do a lowering block and the short shocks to get the bike real low.
You might have to go down on the sidewall height of the tire to prevent top of tire to inside of rear fender "love".
You could also cut down your seat to get a better footing on the ground..
« Last Edit: December 08, 2008, 11:31:56 AM by ProTeal55 »
Offline ProTeal55
  • Est1968.com
« Reply #42 on: December 08, 2008, 11:36:26 AM »
Thanks for the kind words. I currently have a mid 70's CL450 sitting in the garage while I deciede what direction I wanna go with it. The fronts of my old bikes were lowered the easy way. Jut loosen up the top and bottom triple-tree's and let the fork tubes slide up. Once they are both eaqual to where u want them tighten everything up and u are done.
It's my own.
On the CB750 I just built the dual-disc setup with spare parts I and friends had lyin around.
I planned to do it on the green CB450 but ended up selling the bike to my buddy Danny before I could get around to it. The new CL450 project will def. have some sorta modern/dual disc setup on it for sure. I ride way to fast stoplight to stoplight to not have good brakes..
Offline Frankenkit
« Reply #43 on: December 08, 2008, 11:36:48 AM »
The trouble with cutting down the seat is that I just had the seat professionally re-done to be just like factory stock... I'm probably 140# wearing all my gear (128ish in jeans and tee) so I don't know that I'd really likely bottom out my shocks.  I'm not looking to go super, super low, but low to a point where I can comfortably put my feet down while sitting on the bike, (maybe an inch more from where this is now) and have my front end at a proportionate setting so the steering feels about like stock.  I don't care much for any particular 'look' i just want it to feel good for normal day-to-day riding as a newbie.
1973 CL350- Lola?
Stuff for sale
  • Easily Distracted
« Reply #44 on: December 08, 2008, 10:10:50 PM »
I'd say slide the forks up 3/4", or an inch and see how it feels.
Offline cbr-eric
« Reply #45 on: December 09, 2008, 06:00:54 AM »
how have people gone about cutting the seats down?? and chrislib, yours looks awesome!! how did you do it??  any pics of th process?
k8 project, a long way from done.....
Offline ProTeal55
  • Est1968.com
« Reply #46 on: December 09, 2008, 06:52:35 AM »
I would guess you remove the cover and cut down the seat form material to get your ass lower in the seat itself (then recover)...
Offline cbr-eric
« Reply #47 on: December 09, 2008, 08:31:49 AM »
thats sorta what I figured, but is a utility knife going to do the job? and could you just use the stock seat cover pulled around the pan farther??
  • Easily Distracted
« Reply #48 on: December 09, 2008, 10:45:22 AM »
electric carving knife then a side grinder with a flap disc to smooth things up.  Have a look around here >>> http://www.diymotorcycleseat.com/
Offline Frankenkit
« Reply #49 on: December 09, 2008, 11:14:24 AM »
Got the 11" shocks for $79 incl shipping from CycleX.  Guess I'll see in a couple weeks how this goes.  How has everyone been mounting their shocks?  Bike on center stand, rear wheel off, old shocks off, new shocks on (compressed?  grease swingarm while I'm in there?) rear wheel on, bike off centerstand?  Is it that easy?
1973 CL350- Lola?
Stuff for sale
