Author Topic: 75 cb550F, annoying clicking sound?  (Read 1129 times)
550conman
« on: July 16, 2008, 09:07:01 AM »
Looking to identify the clicking sound I experience.  Almost sounds like an exhaust leak at the front left header, but I know that would be far too easy.   A friend who is a long time bike mechanic and actually has done quite a bit of work on this bike and I are perplexed as to what it could be.  Thought about a noisy lifter, valve, etc.  I don't think that is the case either.  Any suggestions welcome...thanks.
MC
Offline greenjeans
  • 1972 CB750K2
Re: 75 cb550F, annoying clicking sound?
« Reply #1 on: July 16, 2008, 09:13:07 AM »
Exhaust leaks are cheap to fix/test  -  just go get a new ehaust gasket & try that first.
Took me 2 tries on one of my pipes to get everything sealed up & tightened properly.
They (exhaust leaks) can really sound like loud/ticking valves.....
Give that a shot first, followeed by checking your tappet clearances & cam chain tension
Offline fastbroshi
  • Puppet
« Reply #2 on: July 16, 2008, 09:50:00 AM »
Or hold a small candle or lighter in front of the suspected pipe and look for a waver in the flame.
Just call me Timmaaaaay!!!
« Reply #3 on: July 16, 2008, 01:56:07 PM »
To isolate an exhaust leak, get yourself some aquarium tubing and hold one end in your ear canal.  The other end can be used as a probe to isolate where the leak, or noise source is.
Given that it is a 75 model.  Lets' hope you don't have cam cover rocker wear, that can allow the tappets to hit the cover.
