Author Topic: Yamaha xs mags compatability?  (Read 1026 times)
lendog
« on: July 16, 2008, 06:11:19 PM »
Does anyone know if the stock mags from an XS would fit a cb750f? The front and rear are both disc brakes.
« Last Edit: July 16, 2008, 08:20:37 PM by LenD73 »
lendog
Re: Yamaha xs mags compatability?
« Reply #1 on: July 16, 2008, 08:23:05 PM »
I think the wheels in question are from an xs650.
« Last Edit: July 16, 2008, 08:29:01 PM by LenD73 »
Offline void909
« Reply #2 on: July 17, 2008, 06:48:50 PM »
I think the answer to this question is how much money do you have. If you want it to fit you can make it fit with the right amount of money. What I would do if I were you is I would get one used off ebay and try it. If it doesn't bolt right up then you can go from there. If its not worth it to you to get it machined then you can just sell it on ebay, you might not get all your money back but its possible.
Hope this helps.
void
knock with no answer
lendog
« Reply #3 on: July 17, 2008, 07:12:16 PM »
Thanks Void. I know someone who has as set. They look just like lesters...and would probably be a lot cheaper. I was just curious to see if anyone has ever done it before. Thanks for the advice. Depending on how much he wants for them I might give it a shot.
Offline void909
« Reply #4 on: July 17, 2008, 07:16:04 PM »
No problem and just think if it does work, you will be the first to find this mod.
Offline TomC
« Reply #5 on: July 17, 2008, 07:24:58 PM »
Hi LenD73
     I have a CB550K with what I think are Yamaha XS, sure they are Yamaha not sure they are XS, Wheels on both ends. This bike is a stalled project so I have not done much with it. It looks to me that the axle diameters are the same. I think that the front is just a little wider that the Honda. In the back spacers need to be made and for my CB550 a brake caliper mount. I have given some thought to using a CB750F swing arm and caliper mount.
     Please keep me up to date if you go a head with this project.
          TomC in Ohio
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
lendog
« Reply #6 on: July 18, 2008, 07:50:14 PM »
Thanks TomC, Just a brainstormed idea right now. If I decide to pursue it i'll keep you posted.
