Author Topic: 1978 CB550K carburetors; Confusion by the Bay  (Read 1523 times)
Offline dnewman417
« on: July 16, 2008, 08:07:51 PM »
Hey there!  I need some help validating what I am doing.  I have a 1978 CB550K with PD46C carburetors, stock air box, and stock exhaust.  All of the connections between the carb, engine and manifolds are good and tight.  I am attempting to synchronize the carbs.  The information that I have for the carbs is as follows:
Float Height:     12.5mm
Main jet:           90
Slow jet:           42
Air screw:          1.5 turns out from closed.
Here are my questions/problems:
1.     The engine will idle, but the number 2 carb (with the fixed, i.e., nonadjustable, arm) will not settle into the correct vacuum range of 16-24 mg/Hg.  What causes this phenomenon?
2.     Adjustments to numbers 3 and 4 mess up number 1 and vice versa.  Why do they effect each other?
3.     Sometimes the engine revs uncontrollably while trying to synch em.  The idle adjusting screw has no effect.  Any ideas? Are the floats sticking?  Have I caused a massive vaccuum?
4.     Does anybody know the difference between the K1, K2, K3 and K4 versus the K.  I have been told that the 1978 550K was a special animal made for the USA and is referred to as the "K" or the CB550K'78.  Are there differences in the carbs for the different bike designations?
5.     What is the proper, stock clip groove for the ring on the needle?
6.     These floats are rectangular and not round.  Where is the float height measured from?
Any assistance would be greatly appreciated.
Dave
Offline dusterdude
Re: 1978 CB550K carburetors; Confusion by the Bay
« Reply #1 on: July 17, 2008, 12:58:25 PM »
hopefully tt or bob will see this and be able to help you out.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: July 17, 2008, 01:32:35 PM »
Forget about the specific vacuum measurement as it's not important at all for synching the carbs.  All you're looking for is that they're all even.  You're not measuring vacuum when doing a carb synch, just getting them all the same.
Adjustments to one carb will always slightly affect the others, so it's a bit of a back-and-forth game until you get the feel of it.
« Reply #3 on: July 17, 2008, 02:24:28 PM »
Cause? The other three slides are not at the same height as number 2.  Make #1 the same as # 2, then make#3 the same as 1&2, then make #4 like the others.  They will then all read 16-24, most likely.  But, whatever they read is fine as long as they are the same.
Engine speed changes cause the cylinder to suck harder or less with RPM fluctuations.
If you adjust one slide down too far, it bottoms out and causes the others to raise.  The other three cylinders then go faster.
K is the model designator.
K0 1974
K1 1975
K2 1976
K3 1977
K4 1978
There are also F models for 1975-77. (F0-F2)
Yes, there are carb differences between models.
3rd groove from the top.
Good question.  On mine, I set them at 14.5 mm, 'cause that is where they are level with the carb body and the 77 model has that spec for the same style carbs, and they were set that way (more or less) when I took it apart..  The engine runs well.  If I felt the need to set at 12.5mm, I think I would choose the float end farthest from the pivot pin as the measurement point.
Offline dnewman417
« Reply #4 on: July 17, 2008, 04:23:48 PM »
Thanks for the info guys.  Thank you especially to TwoTired for answers to my questions.  I now have a plan to follow.
