Author Topic: Polishing Piston Tops  (Read 6396 times)
martino1972
Re: Polishing Piston Tops
« Reply #25 on: July 18, 2008, 10:23:52 AM »
i wouldnt polish them,let the crank settle itself in the way it wants too,just use lots of assembly grease on the journals...
Offline scondon
  • Mmmm......tasty bugs
« Reply #26 on: July 18, 2008, 10:30:21 AM »
 Bearings have a coating on them to prevent wear during installation/ initial start-up. Leave 'em be is my guess.
Offline rbmgf7
  • 2>4
« Reply #27 on: July 18, 2008, 03:25:50 PM »
i figured the bearings were left satin-like to create a no slip boundary between the layer of oil and crankshaft. looking at the crankshaft, the "races" (not sure of a correct term) are polished to almost a mirror like finish which helps glide across the layer of oil. IMO
Offline heffay
« Reply #28 on: July 18, 2008, 04:40:36 PM »
I've never specifically polished piston tops or cylinder domes to a hi gloss... only to remove excess carbon buildup.
as soon as those plugs start firing again i know its all over for those highly polished surfaces.   ;)
now, if i was building a bike for a single drag race... i would polish the crap out of the domes, piston tops and my skull.   8)
heres the extent of my usual work that i consider to be in the "tune up" category... i think it just makes for a sudden revival to the motor's spunk...
3 before and 1 after
after
1 piston top partially cleaned and 1 complete
hey Gordon... what does Manuelle say?
