Author Topic: Carburetor Leaf Spring ~ 550k  (Read 1287 times)
Offline 1975cb550
  • lovin' the old honda's
« on: July 18, 2008, 07:53:10 AM »
I need one because I broke mine. Can anyone help a 550 brotha out???
 I ordered rebuild kits for all my carbs because i want to ride and it's pissing gas. could bad bowl, o-rings/gaskets cause this?? and when I say that I mean cuz the bike leaks from the overflow tubes.
1974 CB750k
1975 CB550k
1998 VTR 1000 Superhawk
Offline Gordon
  • 750K1, 550K2
Re: Carburetor Leaf Spring ~ 550k
« Reply #1 on: July 18, 2008, 08:14:17 AM »
No, bad float bowl gaskets won't cause your carbs to overflow (unless it's protruding into the bowl and preventing the float from rising).  Overflowing is typically caused by a stuck float, debris in the needle valve, worn needle valve or fuel level set too high.
masonryman
« Reply #2 on: July 18, 2008, 09:22:02 AM »
I disassembled a set of used carbs last fall, I may have one, but I am not sure which spring you are refurring to
« Reply #3 on: July 18, 2008, 02:50:11 PM »
If you mean the main jet retaining piece its the same for all 500 and 550 1971 thro'1976 inclusive
