Author Topic: cb 900f shocks on a 77 cb750k?  (Read 2134 times)
crashedupderby
« on: July 19, 2008, 08:05:00 AM »
will the shocks from a 81 cb900f fit on a 77cb750k?
the bike is in my buddies garage and I just found some shocks on CL...so I cant just go measure them...anyone know if they will bolt right on?": change the ride height? pros, cons? thanKS!
lendog
Re: cb 900f shocks on a 77 cb750k?
« Reply #1 on: July 20, 2008, 08:17:07 AM »
Do a cb 900f search in the tech forum .....that'll help you.
« Reply #2 on: July 20, 2008, 08:58:30 AM »
Yes they will bolt right on. But they wont fit with the stock 4-4 exhaust (if the CB900 shocks have the external reservoir). The CB900 shocks are also taller than stock (14`) so may adversely affect handling if at max setting.
good luck
Andy
crashedupderby
« Reply #3 on: July 20, 2008, 10:02:40 AM »
good luck
Andy
4-4 exhaust..ummm no..open straight pipes and cut off just right
« Reply #4 on: July 20, 2008, 01:22:18 PM »
good luck
Andy
The shock is always a 14" shock regardless of the pre-load setting. Putting weight on it will compress it, but relatively speaking it is always longer than stock (13"?) and so wil affect handling by reducing trail and quickening the steering.  It will also affect the way it sits on its stands. The centerstand may not lift the tire off the ground. And check chainguard clearance.
But if the price is right...  ;D
fuzzybutt
« Reply #5 on: July 20, 2008, 03:11:06 PM »
cut, and rethread the shaft. shorten the spring too.
