Author Topic: I got the old bike blues  (Read 1141 times)
Offline MJL
  • Don't listen to me, I'm no
« on: July 20, 2008, 12:19:54 PM »
I've had this bike for a month or so, and have been making repairs and such just about every week. I've noticed that the front end was stiff and decided to change the fork oil. Well, in the pics the seller sent he said the brakes were leaking by the caliper, but it looked to me like the fork seal. It was. When I drained the oil the right side was black and nasty, the left side was all water.  :(  I flushed it out and when I put the drain plug back in it twisted off.  >:(  I managed to get the broken piece off and buy new plugs, then decided to pull back the dust cover. Lots of water and cruddy dirty oil, also some of the chrome is worn off.  :o  So now I'm off to find fork seals with dust wipers.
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: I got the old bike blues
« Reply #1 on: July 20, 2008, 12:27:33 PM »
Just a thought....if the chrome is worn off where the seal is, you may need more then just a seal and boot. :-\ For your sake,I hope not.Just thinking out loud.
.............Paul
Online Johnie
« Reply #2 on: July 20, 2008, 02:31:55 PM »
Yes, pull those forks off and give them a good cleaning.  Get all that water and crap out of there.  You need them clean for the oil channels to flow and give your suspension a good ride.  I sprayed the inside of the lower with carb cleaner and used a shotgun rod to get a cloth down there to get all that crude out.  Good luck with your project...
« Last Edit: July 20, 2008, 02:34:46 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Hush
« Reply #3 on: July 20, 2008, 03:11:32 PM »
Yep them puppies gotta be full of crud, will need pulling and total cleaning.
Should improve handling by about a million percent.
Offline MJL
« Reply #4 on: July 20, 2008, 06:43:54 PM »
They still seem to ride stiff, but not like before.
I have been thinking of trying to fit a Buell front end  :-\
