Author Topic: '76 cb550 trans mainshaft oil seal leak???  (Read 930 times)
Offline c_packer
« on: July 22, 2008, 08:36:18 AM »
Previous to my owning the bike an o-ring chain was installed and it cut through the 34X8mm Needle bearing seal situated behind the drive sprocket. Does anyone know if  I have to crack the cases to replace this seal? If not what is a practicle method of removal? I am a bit of a newbie, but by no means incapable of getting er done. Just looking for some pointers. The Mechanics at the two local Honda shops are in their 20's and haven't a clue.
I'm a creep, I'm a weirdo. What the hell am I doin' here? -Radiohead-
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
Re: '76 cb550 trans mainshaft oil seal leak???
« Reply #1 on: July 22, 2008, 08:59:31 AM »
Cases have to be split to remove that bearing holder....there is a dowel locator pin that it rests within. Complete teardown to remove that mainshaft and get that bearing off the end.
Sorry :(
Offline c_packer
« Reply #2 on: July 23, 2008, 12:59:20 AM »
Thanks, I'll save that for the winter. for now I 'll replace the chain and use some gasket sealer to cover the pin hole.
Online bryanj
« Reply #3 on: July 23, 2008, 05:27:23 AM »
Your hard part will be getting a new plug, might have to settle for a used one from another motor as last i heard they had been discontinued
Offline c_packer
« Reply #4 on: July 28, 2008, 04:05:38 PM »
Found one on the shelf 751 Motorsports in Apex, NC. Gary's been there for decades and is 6 min. from my house.
Online bryanj
« Reply #5 on: July 28, 2008, 08:54:19 PM »
Just shows its worth checking the local guy first, when i was doing it we regularly used to buy an "extra" of what we saw go wrong the first time if we thought it could happen again
