Author Topic: Painting Stinks!  (Read 690 times)
Offline sparty
  • I just play one on TV
    • Gallery
Painting Stinks!
« on: July 22, 2008, 01:32:41 PM »
Well, I have been at it all day.  Taking a break now.  I am painting woodwork and doors at my home, getting the second floor ready for new carpet.  This is the worst!  The woodwork was stained a dark cherry, so after sanding it needs two coats of primer and two of finish.  So far I have the sanding finished in the hallway and one bedroom and a single coat of primer in the hallway and on the door frames.  I installed new six panel doors a few weeks ago and they came with a primer coat - thank God!
Sparty >:(
1972 CB750 K2 Cafe' Style
Offline alltherightpills
Re: Painting Stinks!
« Reply #1 on: July 22, 2008, 05:50:34 PM »
Just curious why you are putting two coats of primer on, what you were planning on using for a top coat, and how you were planning on applying the top coat?  I'm a professional housepainter and we never use two coats of primer unless we are trying to block really bad stains that bleed through the first coat.  For priming woodwork we always use a product by Zinsser called "Cover Stain" and it works great.  It's an oil based primer, which sucks to clean up and you need a black china bristle brush, but it works better than any latex primer we've come across.
What color are you planning on painting the woodwork?  If you are going with white, I would recommend a paint called "Pro Classic" from Sherwin Williams.  It is a #$%* to work with because it loves to sag and run after about 15 or 20 minutes (just long enough for you to forget to go back and check it), but it gives you the hard, durable, and beautiful finish of an oil paint without all of the messy clean up.
Let me know if you have any questions...
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Offline sparty
    • Gallery
« Reply #2 on: July 23, 2008, 09:12:02 AM »
I am using the Zinsser primer, but the woodwork is dark and two coats of primer will help the finish coat cover better (ivory finish).  I am using a Valspar semi-gloss finish and it is a nice paint, I used it on all of my first floor woodwork.  Thanks for your suggestions.
Sparty
