Author Topic: HERE IS A PICTURE OF THE GLASS GAS FILTER  (Read 1654 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: July 23, 2008, 06:10:34 AM »
I had posted a while ago about my glass gas filter...no one seemed to know what I was talking about the center filter in the middle of the glass is replacable. Cant remember the mfg. Got it at pep boys...it is working good and gives you a good peak at what is going on with the gas....I needed it to make me feel better after dirty rusty tank and carb cleanings....
« Last Edit: July 23, 2008, 07:56:46 AM by cb650 bobber »
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline gc8andy
  • Ride Safe
Re: HERE IS A PICTURE OF THE GLASS GAS FILTER
« Reply #1 on: July 23, 2008, 06:35:16 AM »
No picture  ???
1976 CB400F
Offline canttuckmyshirt
« Reply #2 on: July 23, 2008, 07:59:33 AM »
With barb fittings?
I use clear plastic ones with what looks like brass filter in the middle.
72 CB500, Abe Henry wheels
77 CB550, resto-mod
04 S2000, LS1 V8
Offline gc8andy
  • Ride Safe
« Reply #3 on: July 23, 2008, 08:57:07 AM »
there's the picture!
1976 CB400F
  • stupid gloripope
« Reply #4 on: July 23, 2008, 09:30:40 AM »
it is just the angle it is a white filter in the middle ..i think plastic and paper or foam. it has barb ends....i am happy with its performance but have been running a little lean I think from it not warming up fast....was thinking it could possibly be the way i had to route the gas line straight across and then run the gas tube back as the filter is to big to run straight down like one of the smaller inline filters. but I remeber someone saying it didnt matter.
« Reply #5 on: July 28, 2008, 09:37:22 AM »
Emgo makes them too.
77 CB550, resto-mod
04 S2000, LS1 V8
Offline timdhawk
  • 1978 CB750K
« Reply #6 on: July 28, 2008, 10:38:39 AM »
i have one like that that comes apart... easy cleaning!
In deeper than I should be...
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #7 on: July 28, 2008, 10:47:09 AM »
GET THAT OFF YOUR BIKE ASAP !
Think about this one for a min. You have a glass piece holding fuel on your motorcycle.
What happenes to glass if say it were to smack into something ? (it will break).
So say your fuel filter breaks, where does the fuel go ? (all over your warm/hot bike)
What do you think will happen with fuel gets tossed onto a hot motor ? (9 outta 10 times it will catch on fire).
I personally know 4 people who have had fires on their cars (and motorcycles) becasue they used the exact same filter you have on your bike. Not trying to telling you how and what parts to use on your build, just thought I would share some advice. Alittle bit of common sense may save your bike from buring up in front of you...
« Last Edit: July 28, 2008, 10:57:33 AM by ProTeal55 »
Offline jason teamshralp
« Reply #8 on: July 28, 2008, 01:29:55 PM »
ive had no luck with the plastic filters no matter where i put them they always melt, bend, then leak.
  • stupid gloripope
« Reply #9 on: July 28, 2008, 01:35:01 PM »
I was planning on replacing it once  I was sure the tank liner worked never want to clean those carbs agian.....I have to check it out tonight....if there is not alot of dirt in it then  Iwill take it off....pro teal scared me a little.
Offline manjisann
« Reply #10 on: July 28, 2008, 01:42:37 PM »
ProTeal makes a bit of sense. I have the smallest plastic in line filters I could find (one of them is a little pancake looking thing thats actually meant for lawnmowers, but since this is all gravity fed, it works fine.) They are a bit of a tight fit, but so far no problems. I should admit that I have only had my bike up to 60mph, but it worked fine for me.
Thanks,
Brandon
1980 CB650 Custom
  • stupid gloripope
« Reply #11 on: July 28, 2008, 01:45:45 PM »
not sure if I would rather be on fire or clean the carbs and have a non running bike agian.
Offline ProTeal55
  • Est1968.com
« Reply #12 on: July 28, 2008, 01:46:10 PM »
The filters will work fine, untill they crack/leak/get hit by a random rock and explode/etc..
Like I said I have three buddies who watched their cars go up in flames becasue of this exact type of filter, as well as buddy who came out to see his HD Sporty in flames as well.
Not worth it in my opinion...
« Reply #13 on: July 28, 2008, 08:16:01 PM »
These have been around at least 30 years..
After a while they were sold by CR .. the seal guys.. aka Chicago Rawhide..
I used them and thousands of other did in the 70,s & 80,s, and this is the first time I heard of a fire with them.
 My personal observation is the weak point is that they are die-cast..aka potmetal.. make billet ends and you are goodforlife..
 Drag Specialties ( and maybe others), offered them with metal cylinders, and finned too..
 As far as saftey.. 10 gallon glass visible pumps were only 1/4 in thick glass and they held 10 gallons..these are 1/8 inch thick and hold about an ounce... you decide..
 I liked being able to see if gas is flowing but they do get air in them.. where they sit on a sohc motor it is pretty darn difficult to hit them there... just check the threads on them..
  • stupid gloripope
« Reply #14 on: July 29, 2008, 09:25:57 AM »
I checked it out last night still a little dirt in the filter....not to bad just wondering if it might be enough to clog the carbs...I might take a picture tonight and get the dr. sohc opinion aka all of you guys....if the carbs wont clog I will go back to the old filter which was a red cyclindical one but last time my carbs got clogged that was still clean i also saw a clear thinner plastic one at autozone maybe that would be a better choice. I think the tanks is cool after the coating.
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #15 on: July 29, 2008, 04:03:34 PM »
I used to run one of those glass, cleanable gas filters on my VW - a lot of hot-rodders use them. However, I was definitely a bit sketched about the potential fire hazard of a broken one, so I wrapped a piece of high density foam (from an old military sleeping bag mat) around it with a couple of zip ties. Doesn't 'look as cool' but then again, neither would your engine on fire.  :o
On my bike, I use a pair of plastic bodied filters but still with ribbed plastic and neoprene around them. Betta safe than sorry with flammable stuff, me thinks.  :P
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
