Author Topic: SWINGARM LENGTH ???  (Read 3250 times)
grizzzly
SWINGARM LENGTH ???
« on: July 23, 2008, 10:26:24 PM »
I HAVE A 72 CB750K . I WOULD LIKE TO PUT A LONGER SWINGARM ON IT. DOES ANYONE KNOW IF THE LATER MODEL SWINGARMS ARE LONGER OR IF THEY WOULD FIT MY BIKE EASILY. IF NOT ANY SUGGESTIONS, JUST LOOKING FOR ABOUT 3 INCHES. THANKS, JOHN
Offline fastbroshi
  • Puppet
Re: SWINGARM LENGTH ???
« Reply #1 on: July 23, 2008, 10:39:50 PM »
  I don't have a 750, but just hanging around this site you learn some things.  I ran across this bike on ebay a while back and the seller got tons of questions.  He's posted on this site very sparingly, amongst others.  In one of the questions asked of him someone noticed his swingarm looked different, and he did reply that it wasn't stock, but rather one from a later 750, but I don't think it was 3 inches, more like 1-2.
Just call me Timmaaaaay!!!
Offline voxonda
« Reply #2 on: July 24, 2008, 12:02:56 AM »
By my knowledge they are all the same length, maybe look for a swing from a GS1000 or build one. Made mine, awhile back, 2" longer and works.
Good luck.
Offline shoemanII
  • just another bike nut
« Reply #3 on: July 24, 2008, 03:59:07 AM »
what is the length of your swingarm from centerline of swingarm axle to rear axle.  i have one from a '78750k for sale and will measure.
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
« Reply #4 on: July 24, 2008, 05:17:24 AM »
My 72 K2 is 16.5 in. center of pivot to center of axle in full forward position. My 76F is 17.5 in.
I noticed "just 3 inches" in your post. 3 In is a lot. Just curious...why?
« Reply #5 on: July 24, 2008, 05:18:48 AM »
Good luck.
Wow Voxonda, that is kewl! Do I see a gusset above the swingarm pivot? serious stuff. Is it on the road/track now?
Offline eurban
« Reply #6 on: July 24, 2008, 05:24:08 AM »
Late (77/78) swingarms are longer.  How much?  Don't have an exact measurement but somewhere around an inch.
Offline dusterdude
« Reply #7 on: July 24, 2008, 06:12:34 AM »
i know an early cbr swingarm will fit,you will need to make 2 narrow spacers to fit in the frame and the swingarm bolt is smaller so you`ll have to work around that somehow.then you`ll need to to weld on shock mounts.the arm is about 3 inches longer than the k arm
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline voxonda
« Reply #8 on: July 24, 2008, 06:17:44 AM »
I am curious, hope someone has the exact measurements.
Cheers, Rob
Offline voxonda
« Reply #9 on: July 24, 2008, 06:19:01 AM »
Good luck.
See topic: "Preparing for Trackday" somewhere.
Cheers, Rob
Offline .RJ
  • homebase in your airspace
« Reply #10 on: July 24, 2008, 06:23:03 AM »
The 77-78 CB750K swingarms are a bit wider and longer.  Make sure you get the axle and spacers too.
Offline bradweingartner
  • 74 CB 550 x2
« Reply #11 on: August 03, 2008, 09:58:24 PM »
I don't suppose you know if that later CB750 swingarm is wider at the pivot than the CB550?
Offline gerhed
« Reply #12 on: August 04, 2008, 09:16:55 AM »
I have a Kawasaki H2 swingarm that I put in a Honda 350 frame.
It's 22 1/2 inches bolt to bolt.--stock CB750 is about 18 inches.
Hoping for better straight line stability with the longer swingarm as the machine is being prepared for the salt---or something.
<a href="http://i170.photobucket.com/albums/u251/gearheaded_photos/onelungF.swf" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://i170.photobucket.com/albums/u251/gearheaded_photos/onelungF.swf</a>
          83 XL600R in CB360 Frame
