Support the site. Your contributions keep this site running.
The seller lists the one set as being for K1 through K6 models and it has the indentation for the side emblem. But if I am not mistaken (which is very likely), isn't that indentation only really correct for the K1 and K2 models? Later didn't the K3 through K6 side emblems change shape to include a square around them?Here is cover he is advertising for K1 through K6 CB750'sNow it looks as if these K1 and K2 emblems would fit:But not these K3 to K6 emblems:Good chance I will order these as I have a K1 and they look correct, but those restoring K3 through K6's may wish to ask for a correct replica. Unless of course I am wrong. I am new to these CB's so that is very possible.
Quote from: Venturous on July 27, 2008, 05:33:21 AMThe seller lists the one set as being for K1 through K6 models and it has the indentation for the side emblem. But if I am not mistaken (which is very likely), isn't that indentation only really correct for the K1 and K2 models? Later didn't the K3 through K6 side emblems change shape to include a square around them?Here is cover he is advertising for K1 through K6 CB750'sNow it looks as if these K1 and K2 emblems would fit:But not these K3 to K6 emblems:Good chance I will order these as I have a K1 and they look correct, but those restoring K3 through K6's may wish to ask for a correct replica. Unless of course I am wrong. I am new to these CB's so that is very possible.I'm getting all cranked about these covers from over the pond, but alas, no - wrong ones!? I think this may have been answered already but I was too dense to understand. The K1-K6 sidecovers are for all practical purposes exactly the same. Mine (with one slight imperfection ) is pictured below. You can see that it looks like the one in the picture above. hmmmm Mine is a '76 cover. It has indentations that look like they'd fit a '71 or '72 emblem. The newer emblem covers over the indentation "flush"... note the wax/crud outline of the larger/newer "750Four" emblem (which I'm convinced was the way this unit came from the factory).
I REALLY like the air-induction look your side cover has. I'll bet it helps keep that recifier nice and cool!
The K3 through K6 had larger indentations on the side covers, because the "750 Four" logo got bigger and more scripty-looking. Later, I'll try to find some pix of this, gotta go to work now. But...all the K1-K6 covers fit each other's spots on the frames, because the attachment points never changed. This, of course, just adds to the confusion...
i repaired my original ones for basicly free so dont throw away your broken side covers!
Are F and K sidecovers different?
Quote from: Maxacceleration on November 19, 2008, 09:56:19 AMAre F and K sidecovers different?Yes.
Ok then, are the F & K sidecovers interchangeable?Quote from: TwoTired on November 19, 2008, 02:39:41 PMQuote from: Maxacceleration on November 19, 2008, 09:56:19 AMAre F and K sidecovers different?Yes.
