Author Topic: Whats the easiest way to clean the crap off the valves?  (Read 2294 times)
Offline CB750R
  • 77 CB750F
« on: September 04, 2005, 06:07:38 PM »
Hey, I'm rebuilding a head, and the exhaust valves have a brownish deposit thats hard as a rock, on the exposed side of the stem and the head.  I've been carefully sanding this stuff but man its taking forever!!  any way to speed the process up here, or just thank goodness there's only 8 valves?  the intakes are just a little black, and the deposits are easier to remove, but not by a ton.
Thanks
G
Online Terry in Australia
Re: Whats the easiest way to clean the crap off the valves?
« Reply #1 on: September 04, 2005, 06:23:19 PM »
Have you got access to a bench grinder with a "wire wheel" attachment? That's what I use, and it works well. Cheers, Terry. ;D
Offline CB750R
  • 77 CB750F
« Reply #2 on: September 04, 2005, 06:27:04 PM »
D'oh!! knew I wanted one of those for a reason!
Offline heffay
« Reply #3 on: September 04, 2005, 08:59:12 PM »
bead blasters work well too... little trickier to afford tho  :-\
Offline kghost
« Reply #4 on: September 04, 2005, 09:02:16 PM »
Chuck the Valve in a drill.
Spin and use emory cloth. (or sandpaper, it just doesn't last as long)
Stranger in a strange land
Offline heffay
« Reply #5 on: September 04, 2005, 09:08:58 PM »
oooooh!   forgot about that one... works extremely well also... perhaps even quicker than the method i suggested
« Reply #6 on: September 04, 2005, 10:14:34 PM »
Wrap tape round stem before you put it in the chuck.
Offline CB750R
  • 77 CB750F
« Reply #7 on: September 04, 2005, 10:46:45 PM »
now why didn;t I think of that, its how I've been gripping the valves to lap them after all!!! Goes to show you how workin in the garage listening to the classic rock station too long makes the brain turn off!!
Offline Trevor from Warragul
« Reply #8 on: September 05, 2005, 12:44:39 AM »
Buy some caustic soda.  Mix a few teaspoons in some warm water in a glass jar (be careful, it's DANGEROUS stuff).  Put the valves in the jar & leave for a day or so.  The deposits will then fall off.
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline Flood
« Reply #9 on: September 05, 2005, 01:53:02 AM »
I put them in a glass with this foamy oven cleaner for 24 hours, then put them in a drill (with the stems protected with a little strip of cloth).
Then scrape off the residues with something softer then the (hardened) valve. I used hard wood, sharpened. Then use sanding paper.
Offline CB750R
  • 77 CB750F
« Reply #10 on: September 05, 2005, 09:28:31 AM »
Thanks to all the handy responses, its amazing to see how different the methods are to accomplish such a meanial task!! I also shoulda thought about the oven cleaner!! I'm a sales rep for a company specializing in cleaning solutions for restaurants and hotels, I gotta see what I have in the sample dept!!
« Reply #11 on: September 05, 2005, 01:49:32 PM »
Any freeeebees ;D ;D ;D
Offline Lumbee
    • My pics...
« Reply #12 on: September 05, 2005, 08:35:25 PM »
...dremel with the spongy rest remover...works like a charm!
"I'm not a welder, but I play one on HondaChopper.com"
ElCheapo
« Reply #13 on: September 05, 2005, 08:38:38 PM »
Another trick I use is one for a running bike unfortunately. I feed a little bit of automatic transmission fluid while it is running. It seems to work ok, I think.
Makes a killer cloud they can see in the next county :o
Or you can use Seafoam cleaner. When feed through the gas it cleans all the internals nicely. Feed it all at once and you get another killer cloud  :o :o :o.
