Author Topic: cable routing...?  (Read 1448 times)
wornknobby3
cable routing...?
« on: July 25, 2008, 08:18:04 PM »
hey guys, just putting together my 78' 750k, and was curious as to how the throttle cables and choke cable are routed...?
i'm having problems w/ the choke cable b/c with it attached at the bracket @ the handle bars, and it hooked @ the carb, the cable just moves, i see there is a bracket @ the carb right above where the choke cable connects but not sure if this has anything to do w/ the cable??
 i just wanted to know if there were any brackets or anything that the choke cable especially need to be attched.. any help is greatly appreciated. thanx
Offline jtb
  • An unlikely
Re: cable routing...?
« Reply #1 on: July 25, 2008, 08:42:40 PM »
There is a bracket above and behind the throttle wheel.  Clamp the choke cable in this.
1977 CB750F
1985 V65 Sabre
wornknobby3
« Reply #2 on: July 25, 2008, 09:08:47 PM »
ok, yea i see where your talking about, i just tried and i think i almost had it, i had the cable pretty much runing the line of the frame ,and it seemed to want to work in this position,
 but now i have yet another question about the bracket...
that little arm that has the little Phillips head screw on it.. what is that's purpose? is it supposed to be clamping the cable? and if so which way to you have the arm, facing upwards or downwards towards the carbs?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: July 25, 2008, 10:36:34 PM »
photos?
it;s a bit dark out to look, but I have a good memory ;D
Offline jtb
  • An unlikely
« Reply #4 on: July 26, 2008, 05:44:20 AM »
The bent tip on the bracket goes on top.
1977 CB750F
1985 V65 Sabre
wornknobby3
« Reply #5 on: July 26, 2008, 09:56:05 AM »
so the cable runs the backbone of the frame, and curves down? that makes sense, so by looking @ the pic, i need to turn the little bracket counter clockwise inoder for it to be in the right position correct? this would make sense... sorry for the little details, i'm just rebuilding this bike from the ground up, and all i started w/ was a frame and a motor, nothing else, so i'm slowley but surley getting there, and thank for the help guys ;D
Offline jtb
  • An unlikely
« Reply #6 on: July 26, 2008, 11:40:48 AM »
here's mine
1977 CB750F
1985 V65 Sabre
wornknobby3
« Reply #7 on: July 26, 2008, 12:06:40 PM »
nice thanks dude that helped a ton, my bracket was on the otherside facing the other way, you just saved me a night of aggravation... ;D
its working smoothly now
