Author Topic: 500 Carb Mixture Adjustment?  (Read 857 times)
Offline Loudpipe
  • Broken Vehicle Collector
« on: July 26, 2008, 02:28:36 PM »
Where is the mixture adjustment on the 500 carbs?  #1 is a little lean...
Also, there is a screw on top of each carburetor that has a slotted head, indicating it's used to adjust something, and two nuts on it (locking it in place).  Also has a thin metal "strap" that connects the same adjustment together on the 1 & 2 and 3 & 4 carburetors.  What is this? (The double nuts were a little loose and I need to tighten them up, but just wondering what it was).
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Re: 500 Carb Mixture Adjustment?
« Reply #1 on: July 27, 2008, 04:36:54 AM »
Mixtur screws are on the side of thr carb at an angle unless it is a 77/78 K3 in which case they are verticle underneath at the front.
Those screws on top should have a screwdriver slot on the bolt with one nut and are for syncing the carbs
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: July 27, 2008, 07:14:43 AM »
If the lock nuts for the slide adjusters (top of the carbs) are loose, then your carbs need to be re-synchronized before you tighten them back up.
Offline Loudpipe
« Reply #3 on: July 29, 2008, 11:03:55 AM »
K.  The mixture screws... do they adjust air flow or gas flow?  I'd assume gas, but the manual calls them "air" screws.  And which way is which (clockwise/anticlockwise... just to be sure).
Could carbs being out of synch make the bike idle really out of wack?  It was doing moderately ok, and then today I took it out for a spin, and no matter how I finely I turn the idle adjuster, it wants to do either 2500rpm or none at all.
- LP
1974 Honda CB350F
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #4 on: July 29, 2008, 11:57:42 AM »
They adjust air flow through the idle jet. You can easily
remember that because the screws are on the intake side
of the carbs. So, turn them IN to idle richer, OUT to idle lean.
Oh yeah, definitely. Synch those things ASAP.
« Last Edit: July 29, 2008, 12:00:07 PM by number13 »
Bikes parked out front mean good chicken-fried steak inside.
Offline Loudpipe
« Reply #5 on: July 29, 2008, 01:05:49 PM »
Thanks for the help.
- LP
1974 Honda CB350F
