Author Topic: lighting quesion  (Read 1600 times)
keener
lighting quesion
« on: July 26, 2008, 04:18:40 PM »
Hello, I am trying to get my speedo and tach lights working. All other lights work fine and I cant figure out why these lights wont go. Isnt all the lights running together or on the same common current? Any tips would be great!
Offline WFO
  • Will work for powerbands
Re: lighting quesion
« Reply #1 on: July 26, 2008, 04:25:06 PM »
1st Can you verify power in getting to the instruments?
82 cb650 sc nighthawk - 78 kz 650 b
keener
« Reply #2 on: July 26, 2008, 04:25:55 PM »
when the key is turned on there is no voltage that i can read. And the connections are all good
Offline WFO
« Reply #3 on: July 26, 2008, 04:27:59 PM »
Check your fuses then even a fuse that seems good could be bad so replace with new one to eliminate that as an issue.
wornknobby3
« Reply #4 on: July 26, 2008, 04:28:46 PM »
what i would do is find a wire that is constant feed when the key is on and splice your lights into that wire. unless your trying to keep your harness together then maybe its a ground issue?
keener
« Reply #5 on: July 26, 2008, 04:36:57 PM »
I got my speedo lights going but still no tach lights.... look like a bad connection. and I found it. Thanks all!
« Last Edit: July 26, 2008, 04:40:23 PM by keener »
Offline WFO
« Reply #6 on: July 26, 2008, 04:50:52 PM »
Great news! it's always good news when you can avoid the hammer test.  ;D
