Author Topic: Wider plug gap for electronic ignition?  (Read 1572 times)
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« on: September 05, 2005, 10:17:43 AM »
I told someone that I had replaced the old points ignition with an electronic ignition and added new coils and wires. They suggested that I widen the plug gap to take advantage of the better spark capability. Any thoughts on this?
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Re: Wider plug gap for electronic ignition?
« Reply #1 on: September 05, 2005, 10:30:50 AM »
If your new coils have 3 ohm primaries, you can add about .005 inch to the spark plug gap to add some efficiency to the combustion process.  If the new coils are 5 ohm, keep the stock spark gap.
This assumes the wires, plug caps, and voltage to the coils are of optimum condition and strength.
Also, use either resistor caps or resistor plugs but not both.
