Author Topic: Pictures of what has been happening...  (Read 9310 times)
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
« on: July 28, 2008, 04:26:56 PM »
Had a chance to shoot a couple pictures of my bike as it sits.  I'm stupid-busy traveling and working this summer, but hopefully the bike will come together in short order.  Hope you enjoy, because I do :)
http://www.flickr.com/photos/babyfood1217/sets/72157606427906169/
-Chris
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
Offline scondon
  • Mmmm......tasty bugs
Re: Pictures of what has been happening...
« Reply #1 on: July 28, 2008, 04:37:06 PM »
 Some serious re-engineering going on there, babyfood. I dig it, thanks for the pics :) :)
« Reply #2 on: July 28, 2008, 04:37:37 PM »
Reminds me of the biker build off episode where billy zane made his exhaust exit from under his seat.  On the trip to the bike show where it was to be judged, he actually lit the seat on fire!
It was so danged funny, cause while he was building it earlier, I told my wife it was going to be a hot seat ride, and needed a heat shield separator, which never even occurred to him, the expert chopper builder. ;D
Offline scondon
« Reply #3 on: July 28, 2008, 04:40:07 PM »
   I remember that episode, called to mind a Mr. Bungle song.....
.........."it's not funny, my ass is on fiiiiiire" ... :D :D
  • I miss my baby...
« Reply #4 on: July 28, 2008, 04:40:19 PM »
Ah hah, heat shielding considered and in the works.  I thought about it too, but my first attempt on the undertail (remember me getting torn apart on this forum ;) ) never had a problem with temps, and this version has even more space and airflow underneath.
-chris
SOHC member: #438
Offline scunny
  • don't call me expert
« Reply #5 on: July 28, 2008, 04:47:22 PM »
I remember the gnashing of teeth with the last undertail....haha
looks like another radical machine so good luck to you
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline cleveland
« Reply #6 on: July 28, 2008, 04:57:22 PM »
He's back!!!  Looking good man.  I for one dig the exhaust!
Got any build pics of that tank build?  It almost looks like a backwards 77 tank modified.
Offline fastbroshi
  • Puppet
« Reply #7 on: July 28, 2008, 05:38:16 PM »
Ha ha, your welds were going through hot glue...I'm not even going to ask.  That looks like a 600rr muffler, maybe you could get the heat shield from that as well.
Just call me Timmaaaaay!!!
  • I miss my baby...
« Reply #8 on: July 28, 2008, 05:52:48 PM »
Good eye fastbroshi.  I don't recall what year, but it was an eBay purchase.  Heat shield doesn't fit unfortunately.  It's pretty tight in there.  The plan for the heat shield is a pairing of homemade aluminum sheeting (fabricated) and adhesive backed heat shield (the kind you can put on the inside of body work.)  I've tossed around the idea of corrugating the aluminum, but I doubt I'll even need to do that.
As for the hot glue...I began mocking the tank up by trimming and fitting cardboard sections up against the bottom portion of the tank (I already trimmed the top half off.)  Gluing the pieces up as templates, I was able to determine the remainder of the tank that needed to be trimmed, and how the assembly should go.  I was lazy (obvisouly) and didn't clean anything off ANY of the metal surfaces.  Not paint, not clearcoat, not hot glue, not rust, not anything.  I just turned the welder to max amperage with .030 fluxcore (ran out of gas) at mid-range wire speed and went away at it.  I'm planning on (once it is welded tight) flushing the inside with a tasty menu of strippers (chemical ones, not pretty ones) and then doing a POR-15 tank seal kit.
SOHC member: #438
Offline scondon
« Reply #9 on: July 28, 2008, 11:47:03 PM »
 What about the clutch then? ;)
Offline Hush
« Reply #10 on: July 29, 2008, 01:10:34 AM »
I see he has found the perfect solution to those troublesome carbs too!
  • I miss my baby...
« Reply #11 on: July 29, 2008, 01:51:12 PM »
forget the carbs...Open the petcock, and the dripping fuel gets blown toward the intake ports by the turbulent air, and it will be the perfect atomization of fuel with air to create ideal combustion :)
-Chris
SOHC member: #438
Offline jason teamshralp
« Reply #12 on: July 29, 2008, 02:46:41 PM »
Isn't Billy Zane the same guy you made a kick only harley with three chains instead of a belt and couldn't get his bike to start? it also ate every pair of pants he rode the bike in. I've also seen a bike he built with a one gallon gas tank that could barley make it from gas station to gas station. I hate that guy, He makes the OCC guys look good.
martino1972
« Reply #13 on: July 29, 2008, 03:10:16 PM »
i think his name is billy lane from choppers inc.
i remember the episode,trying to kick start that thing like mad,didnt indian larry help em out later on in the show to set up different carbs??
he also burned a bike down to the ground from a leaking fuel tank on a biker build off show..
he makes crazy looking bikes,but i dont have em too high up for being a bike mechanic..
this is his website:http://www.choppersinc.com/
Offline acteg
« Reply #14 on: July 29, 2008, 03:52:10 PM »
Believe it or not the guy is a mechanical engineer. (billy lane)
fuzzybutt
« Reply #15 on: July 29, 2008, 05:46:58 PM »
and looking at MAJOR prison time for vehicular homicide
Offline acteg
« Reply #16 on: July 29, 2008, 07:22:11 PM »
Yep, I was living in Melbourne at the time.  Evidently he was on a suspended license when he killed that guy DUI (IIRC).
Offline bradweingartner
  • 74 CB 550 x2
« Reply #17 on: July 29, 2008, 07:27:27 PM »
REALLY like that tank, and the way the rest of the bike is coming together.
But for future reference, when building a tank, shortcutting the welding is usually the last thing you want to do unless you like leaks! Hope the POR15 works out for you though  ;)
What kind of welder do you have that didn't make complete swiss cheese of that 18/16ga sheet metal at full tilt on .030 flux core?
Offline alltherightpills
« Reply #18 on: July 29, 2008, 07:34:32 PM »
Listen to your friend Billy Zane.  He's a cool dude.
http://www.imdb.com/name/nm0000708/
Glad to see your back at it babyfood.  It's good to see some curveball approaches to these bikes.
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
« Reply #19 on: July 30, 2008, 02:04:31 AM »
Glad to see this topic is off track as much as it is on track.  :D
  • I miss my baby...
« Reply #20 on: July 30, 2008, 08:14:26 AM »
I know not the best approach for the tank, but...
I will be coming back in to lay a thoroughly penetrated bead on every seam, it will be leak test, and any final spots can either be welded again, brazed shut, or I have even heard of people using body lead (old school body filler) to fill in any seams.  It will be tight and without leaks before the POR-15 goes in.
My ideal approach would have been to use Aluminum rather than steel.  Steel can be great, but this tank is going to be rather heavy (16ga.)  Original tanks are stamped, so thinner gauges can be used, maintaining strength without adding weight.  But Aluminum...lighter and just as durable.  Anyhoo...
SOHC member: #438
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
« Reply #21 on: July 30, 2008, 08:51:06 AM »
Looks great, and it has a cool design. You have your work cut out for ya. I'm interested to see how that exhaust will sound.
What is that black thing mounted on your fab'ed clutch cover?
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Offline Porscheguy912
  • I'm a Big Shot Ninja.
  • It's MR. Moustache To you SIR!
« Reply #22 on: July 30, 2008, 09:01:33 AM »
Another Mr. Bungle Fan?? Awesome! :)
And and interesting project you have there.
Current: 1978 CB750F3
Past: 1974 CB550K
  • I miss my baby...
« Reply #23 on: August 01, 2008, 07:17:50 PM »
Just thought I would interject quickly (thread jacking from myself?)  I've wanted to do a modern fork conversion for a while, but don't have the money.  Well, I got bored (and lazy) and did a crappy PS/AI of my bike with a buell XB front end and some sort of sportbike rear section.  This way I could switch between a rear seat pad and a rear cowl, and still maintain the quasi sport-bike-street-standard-naked bike I love.
-Chris
SOHC member: #438
  • 74 CB 550 x2
« Reply #24 on: August 03, 2008, 06:02:47 PM »
I've been putting together the parts for a modern front end. I love the look. I have to say that I REALLY like that buell front end though...
Got my gears turning now.
