Author Topic: CB400F Cam Chain Tensioner  (Read 853 times)
84Olsen
« on: July 31, 2008, 01:25:29 PM »
Hello.
Im new here, and I have a problem with my tensioner bolt on my CB400.
I notised a oil leakage, and I found out that the oil came from a broken tensioner bolt. The bolt has broke off just under the o-ring.
Does anyone have a fix for his prob?
Re: CB400F Cam Chain Tensioner
« Reply #1 on: July 31, 2008, 08:20:52 PM »
Remove and strip engive, have bolt drilled out and thread helicoiled-----you did ask
Offline Joel
« Reply #2 on: July 31, 2008, 08:49:09 PM »
If you're careful and patient, you can drill down the center of the broken bolt and use an extractor to remove it.  I had to apply some heat to the area as well to get mine loose after I sheared it off inside the hole.
http://forums.sohc4.net/index.php?topic=35331.0
