Author Topic: info required  (Read 1743 times)
des46uk
info required
« on: September 06, 2005, 11:51:23 AM »
hi all,hope you dont mind me asking for help in identifying a 1978 cb750f ohc i have just got,and need help in identifying it before i get the wrong parts,the frame no is cb750f-1038116,
engine no is cb750E-2560607  i have been told its an F1 and even on on some old reciepts its an F1 but on others its down as a k7.i would be most grateful for any help that you could give.
        regards
        des
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Which model do I have?
« Reply #1 on: September 07, 2005, 04:11:31 AM »
I'm not a 750 man but I thought that the F-models had engines that started CB750FE-xxxx
You could try PM-ing Bryan Jones (bryanj) as he might be able to help with the numbers.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
sohc4
Re: info required
« Reply #2 on: September 07, 2005, 05:45:36 AM »
From the numbers, that should be a K6 engine.  See http://www.satanicmechanic.de/enginemods.shtml for engine numbers and modifications.
All the best,
Axl
Re: info required
« Reply #3 on: September 07, 2005, 08:53:40 AM »
1975 cb750f0 with a 1976 cb750k6 engine IF its a US bike
des46uk
Re: info required
« Reply #4 on: September 07, 2005, 11:31:04 AM »
thanks all,as you can tell i am a newbie to the cb750 at least now i have some idea which mongrel i have,i am going to get in touch with the dvla and see if they can put any more light on it,i dont know if it is or was a US bike as i am totally in the dark with it.
        cheers again
        des
Re: info required
« Reply #5 on: September 08, 2005, 05:34:22 AM »
It sounds like you are in the UK. If so give me a ring on 07795162623 any evening Sunday to Thursday and I will advise you on reg with unhelpful DVLA.
des46uk
Re: info required
« Reply #6 on: September 08, 2005, 10:03:55 AM »
cheers brian,will give you a call sunday eve,much appreceated
des46uk
Re: info required
« Reply #7 on: September 08, 2005, 10:09:21 AM »
P.S. i am actually in rugeley staffs.
Re: info required
« Reply #8 on: September 08, 2005, 01:39:02 PM »
Handy for the classic bike shows!
Welcome to the forum Des.
Sam, in Warrington.
des46uk
Re: info required
« Reply #9 on: September 09, 2005, 04:37:31 AM »
cheers sam,yeah i'm hoping to go to the one in october at stafford,i am hoping to pick up some bits for my cx500 as well as the cb750 heinz.
                                                       des
Offline mcpuffett
Re: info required
« Reply #10 on: September 09, 2005, 04:42:05 AM »
hello fellas ,mick up north ere,i will be going to stafford in october on a parts finding mission  ;).
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
Re: info required
« Reply #11 on: September 09, 2005, 05:47:27 AM »
It seems that in the UK the F0 frame number often left the factory with F1 engine numbers. I've seen several now.
In the UK anything over 40 years old only needs insurance and Fuel.
des46uk
Re: info required
« Reply #12 on: September 09, 2005, 11:34:11 AM »
hey mark,thanks,if i wernt confused earlier i am now,an old chap at work(bit older than me)says mines an f1,but with so many look a likes its hard to pin point which one i do have.after brians reply the other day i looked at wat he says mine is,and guess what,its like every one ever made,lol.even a kwak headlight.think i will be doing better than you mick from the look of it i can put anything on mine.
                     des
