Author Topic: Any 6 volt Honda Guru's out there? (Honda S65 Question)  (Read 1456 times)
Swoop
« on: August 05, 2008, 05:13:47 AM »
Hi
I have an S65 and am looking for some info.
The turn signals will only start to flash when I get the revs way up there. I do not have a manual (Don't say it...I know  ::) )
Anyway...I am thinking of the lighting coil maybe? Any other suggestions. (Yes it is a 6 volt flasher)
Headlight won't come on at idle either....but requires less revs to bring it on.
Thanks for any help.
Steve
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
Re: Any 6 volt Honda Guru's out there? (Honda S65 Question)
« Reply #1 on: August 05, 2008, 06:21:50 AM »
Steve: Had the same problem with my S90. Probably not the flasher unit (unless it's a 12V).  They either work or don't. Since both sides are the same, would start with the grounds. Mine are all tied into a common ground. Cleaned all the terminals (+ and -), all the sockets, and made sure all the connections were tight and now they flash even when not running.
Fonda Honda
Offline grumburg
« Reply #2 on: August 05, 2008, 06:25:11 AM »
PS : Since your lighting is dim, appears your charging system is not putting out enough juice. Not much room for error with only 6 volts. Should max out about 7-7.2v.
Fonda Honda
Swoop
« Reply #3 on: August 05, 2008, 09:32:53 AM »
My local wrench here said that maybe the rotor has lost it's magnetism....???? How the heck do you check for that?
Steve
bikebitsintheloft
« Reply #4 on: August 05, 2008, 11:12:22 AM »
hi ide go back to the earth , no punn intented . i had the same problem with my c90 , dont know what type of indicators you have but mine earthed directly with no extra earth cable run so i had to nip the mounting bolts up a bit more and hey presto they worked ... Gaz
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #5 on: August 05, 2008, 01:43:13 PM »
What condition is your battery in?
New or unknown? Is the fluid topped off?
Bikes parked out front mean good chicken-fried steak inside.
Swoop
« Reply #6 on: August 05, 2008, 02:50:00 PM »
Thanks fir the suggestions.
I have over 6 volts sitting...7.1 revving.
Headlights seem fine...even aat idle....but turn signals won't cut in till 2-3000 grand????
And then not reliably.
This sucker is positive groung no?
I am getting continuity everwhere.
Any more suggestions?
Steve
Offline number13
    • Sound Exchange
« Reply #7 on: August 05, 2008, 04:30:08 PM »
Try an electronic flasher, those old mechanical
flashers take a lot of juice to operate.
On a different note, I drove a 53 Chevy with original
6 volt system for 11 years (1989 to 2001), I found it ran a lot better
with an 8 volt battery. The generator and regulator
put out plenty to keep it charged and starting was
much crisper.
