Author Topic: 750 K0 transition questions/mystery seat  (Read 3800 times)
Offline zoo mob
« on: August 05, 2008, 10:48:40 AM »
So I'm working on getting parts in preparation for a complete restoration of my 6/70 build 750 K0. Mine seems to be a bit of a K0/K1 hybrid, it had a non-honda seat when I got it, but had the later model locking seat latch with a key that matched the flush ignition. I'd assumed all k0's came with a duckbill seat, is not the case. The bike does have the larger sidecovers, K0 gauges etc. Also, the parts bike I'm picking up has some older parts as it is a 1/70 build, recessed ignition etc, what is my best bet for figuring what parts would have originally come on the bike? I want it to be authentic, but I don't want to end up building a fake sandcast.
« Last Edit: August 05, 2008, 11:36:05 AM by zoo mob »
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline markjenn
  • CB750K1, CBX, RC30
    • Whizmo and Gizmo
Re: 750 K0 transition questions
« Reply #1 on: August 05, 2008, 11:10:33 AM »
Not sure if this is useful, but I have a K1 and it doesn't have a keyed seat.  So sounds like your seat latch is post-k1.
- Mark
Offline zoo mob
Re: 750 K0 transition questions/mystery seat
« Reply #2 on: August 05, 2008, 11:43:30 AM »
OK, the mystery deepens...I just took a second look at the seat that came with the bike, and it is clearly made atop a K0 seat pan, the bottom is identical with the ducktail from the parts bike, it has red foam, same latch, seat rubbers, aluminum trim etc. Does anyone recognize it as an aftermarket seat, or is it likely just an upholstery shop special? I'd thought it was just some random seat that had been thrown atop the bike, but it looks like it might make a good start for someone.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Offline Johnie
« Reply #3 on: August 05, 2008, 12:10:43 PM »
My KO has a build date of 1/70 and does not have the keyed seat.  It does have the recessed ignition.  Both these items are unique to the sandcast and KO models.  When they discontinued the recessed ignition and started the keyed seat maybe someone knows.  Those appear to be OEM Honda pans to me.  Your pans have the 4 holes at the back in the arc and I believe that pattern was on the sandcast and KO.  The K1 has 3 large holes at the back.  Below is a pic of the seat latch on the KO.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline dusterdude
« Reply #4 on: August 05, 2008, 12:14:51 PM »
xactly
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
« Reply #5 on: August 05, 2008, 12:15:27 PM »
since we are on the subject.if anyone has a k1 latch assembly they want to sell,give me a holler.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: August 05, 2008, 01:59:01 PM »
I have a latch from an early '72...if that works, it's yours.
Offline Clyde
« Reply #7 on: August 05, 2008, 06:43:40 PM »
Both seats look original K0/K1 seat pans, but the one on the left appears to have been cut down and reupholstered.
The key lock was introduced with the K2, but can be retrofitted to the K0/K1 frame.
The bracket for the key lock will bolt on to the early frame. The seat is different and would either have to be changed to a K2 seat or modified to fit the plunger for the key lock.
6/70 would be the last month of the K0 and should have a recessed key switch. However a lot of these switches failed over the years and were replaced with later ones. If the PO had fitted a key seat lock then he probably replaced both locks anyway
I have seen an early K1 with ducktail seat and larger frame sidecovers but with rod operated carbs.
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline zoo mob
« Reply #8 on: August 05, 2008, 08:03:24 PM »
So if I take the recessed ignition off the parts bike, will I be able to get a key for it?
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
« Reply #9 on: August 05, 2008, 09:27:59 PM »
Honda dealers used to have a box of spare keys, if you showed you had the number , they should sell you one..
if they dont ask, get a spare for your buddys 750, and move it once in a while, just a few feet.. when the fork is locked.. drives em freaking nutz... ;D
 If you ride a lot you may want to save the recessed one for later.
I have 2 question re Honda keys I wonder about..
 Can a non-collared key still fit in a recessed ignition/?
 Does a keycutter machine exist??
By keycutter I mean like Schwinn uses.. send a guy with a cutter your lock number and the hand tool will cut a key that fits!!
Offline Clyde
« Reply #10 on: August 05, 2008, 10:32:11 PM »
Check to see if there is a number on it-for example T4546.
If so, there are a few sellers on eBay selling keys which will have a matching (hopefully) number.
Any good locksmith should be able to match a key for the lock, but it may be expensive.
A non collared key will fit the recessed ignition. My 5/70 K0 has ordinary keys, but I am still looking for an original key (but I am not sure whether I will live that long)
SOHC4 #1909
« Reply #11 on: August 06, 2008, 01:14:03 AM »
I have a K1 seat latch on my 1/70 K0 seat, I'd be happy to give it to Dusty, if a kind soul here would send me their spare K0 latch...........  ;D
fixahonda
« Reply #12 on: August 06, 2008, 06:59:08 AM »
When I worked at a VW dealer we had a code cutter. You used the dies you needed for whatever key you were cutting, looked in the book to translate the key code into the cutter code and chopped away. It was nearly fool proof.
I'm sure most locksmiths still have some such device. It would be finding the proper Honda blanks that might take a while.
Offline 736cc
« Reply #13 on: August 06, 2008, 07:05:44 PM »
hondakeys.com has nos plug keys available
Offline dusterdude
« Reply #14 on: August 07, 2008, 10:17:49 AM »
sherriff,you`re a sweetheart. :-*
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
« Reply #15 on: August 07, 2008, 08:42:34 PM »
Have you posted any pics of the finished resto yet John? My eyes aren't good enough to enjoy your avatar pic, but the pic of your seat latch shows just a hint of some of the beautiful detail! Cheers, Terry. ;D
Offline Johnie
« Reply #16 on: August 08, 2008, 07:34:06 AM »
Yes Terry, I had posted some.  Take a look at the September Bike of the Month thread and there are some there.  Thanks for asking.  ;D
Oshkosh, WI  USA
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #17 on: August 08, 2008, 10:12:10 AM »
one of my local honda dealers still has one. you tell them the number, they dial it in, then it cuts your key. they're pretty expensive, so when they broke apparently few dealers replaced them.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #18 on: August 08, 2008, 11:47:18 AM »
Me, too. My first one. I traded it for my present K2 in early 1971.
« Last Edit: August 08, 2008, 11:49:49 AM by HondaMan »
