Author Topic: gas in carb venturi?  (Read 844 times)
Offline friedfish80
« on: August 05, 2008, 02:06:24 PM »
Like mentioned in the title i got gas sitting in the venturi of carbs 3, 4. I keep the petcock shut off when its not sitting. Also when i pull the pod filters off and run the bike and rev the motor it sprays gas from the venturi. Whats causeing this and how do i fix it?
martino1972
Re: gas in carb venturi?
« Reply #1 on: August 05, 2008, 05:49:30 PM »
you got leaking intake valves,blowing some of the compression from the engine back into the carbs..
this reversed airflow takes along fuel as it would going into the engine....
martino1972
« Reply #2 on: August 05, 2008, 05:52:11 PM »
or you have to set your valve clearance...maybe its so out of adjustment that it keeps the intake valves open a little...
Offline friedfish80
« Reply #3 on: August 05, 2008, 05:55:59 PM »
so i got air blowing back from the motor as its not running?????
spooky :o
martino1972
« Reply #4 on: August 05, 2008, 06:00:12 PM »
your telling me that it spray's fuel out of the venturi when its running.....
sitting still it would creep me out if it sprayed fuel back out of the carbs.. ;D ;D
if,lets say,it overflows when sitting with engine off,it should pour out of the overflow hoses at the bottom of the carbs,unless they are plugged...
Offline friedfish80
« Reply #5 on: August 05, 2008, 06:05:34 PM »
noting comeing out the bottom. noting pluging them. i even shut off the fuel as i pull on my street or as i pull into a parking lot to lower the fuel levels in the bowls
Offline Pinhead
  • 1979 CB652-ST
« Reply #6 on: August 05, 2008, 06:57:32 PM »
My old SL175 would do that as well. Never could figure it out. However, I will say that my 650 won't even run without the air filter in place... Maybe the lack of restriction is reaping havoc on the carbs?
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
