Author Topic: New to List with a New (to me) 400  (Read 2238 times)
tevoigt
« on: September 06, 2005, 06:00:51 PM »
Hello all.  I have been lurking here for a couple weeks.  I came across a 1977 CB400 for a very good price and picked it up about three weeks ago.  All I knew about it was that it has been sitting in a garage since 1987 or so.  So I figured I would go have a look.  It looked surprisingly in good shape, crome was a little rusted but salvagable, no battery and hadnot been started since nobody knew.  I figured I would try to bring her back to life.  I got her home and got a battery, plugs, oil change and so forth.  She would crank but not start, had some spark but, since I have never owned a bike so old, I was not sure if it was strong enough.  Decided to clean the carbs, bought some rebuild kits (Keyster, after I ordered them I read some of the posts on this site) I used the kits anywhay.  I bench sinced the carbs(thanks to the carb faq from here) put the carbs back on and bingo she was running.  Sound strong and runs reasonably well through the gears.  I still need to fine tune the carbs.
I need to decide if I should go with pods ar the stock air box (I do not have the pice that conects the airbox to the carbs( Snorkle??)  Any suggestions would be appriciated I am going to post in the parts section also.
I also will need new handlebars, the previous owner installed AgeHangers, ouch!!!
I will post some pics soon
By the way My name is Tom and I will gladly accept any constructive advice and or critisisms(sp).
Thanks and ride safe
Offline Uncle Ernie
Re: New to List with a New (to me) 400
« Reply #1 on: September 06, 2005, 06:37:51 PM »
That "snorkle" thingie shrinks up with age and you lose the proper connection (well, mine did). I went with the pods. Seems to run OK, but it sounds much cooler, so who cares how it runs!
Hope to God you replace the tires soon.
tevoigt
« Reply #2 on: September 06, 2005, 06:58:41 PM »
Yes tires are on the list
Offline heffay
« Reply #3 on: September 06, 2005, 08:30:40 PM »
recently bought drag/clubman bars for my 400 project and have the original 77 bars if you would like them.  will trade something of value... let me know.
heffay
Offline kghost
« Reply #4 on: September 06, 2005, 08:35:39 PM »
Don't forget to take the good natured ribbing as well.  ;D
I think I have a headlight ring if your just missing that and not the total bucket.
Stranger in a strange land
Offline 74cb750
« Reply #5 on: September 07, 2005, 06:52:16 AM »
Welcome to the boad Tom,
I have a headlight bucket from a 1974 cb350F if that will fit your needs. Let me know & I'll check the "HM-##" to verify.
michel
Laugh at least once a day.
Life  $ucks, then you die.
Offline 78 k550
« Reply #6 on: September 07, 2005, 05:41:01 PM »
Welcome,
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
