Author Topic: CB650 retro-racer  (Read 43504 times)
Offline Zaipai
    • My Home page
Re: CB650 retro-racer
« Reply #150 on: May 11, 2010, 04:20:14 AM »
will do, have a spare one but haven't checked it out yet, hopefully if I've kissed a valve it better be the exhaust since I bought 2 sets when doing the motor up
Man I hope you haven't kissed a valve, or at least if you have then I hope its the ones you have spares for..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline The_Crippler
  • Work in progress.
« Reply #151 on: May 11, 2010, 06:34:13 AM »
.: Scott :.
Okay...excuse the dumb question - but I haven't heard this term before.  "Kissed a valve?"
Offline Frankenkit
  • Industrial Strength
« Reply #152 on: May 11, 2010, 08:54:02 AM »
where you jump your timing and a piston hits a valve that's still open.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
  • Work in progress.
« Reply #153 on: May 11, 2010, 11:46:10 AM »
...and what is the end result?  (I mean, aside from a busticated motor.)
Offline scunny
  • don't call me expert
« Reply #154 on: May 11, 2010, 11:58:09 AM »
worse case holed piston. hopefully just a bent valve. I don't know when the adjuster went, the bike was running great and no bad noises. started it up let her idle for a while then turned it off. when I tried to restart it I initially blamed the battery and tried to push start.
« Last Edit: June 16, 2010, 08:17:23 PM by scunny »
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
  • Work in progress.
« Reply #155 on: May 11, 2010, 01:47:14 PM »
Thanks for the explaination.  Learn something new, etc.
I really hope your case isn't anything serious.
Offline scunny
« Reply #156 on: May 14, 2010, 11:02:25 PM »
front cam chain holder snapped in half, no sign of scoring on it or the tensioner itself. no 1 inlet valve has enjoyed tapping the piston and is slightly bent, other than that no damage.  ;D
photos when it's light outside. very strange. I've got a spare so no bother there but will contemplate my navel for a while, could my cam chain have suddenly stretched ?  doubtful, only splitting the cases would show that so navel gazing it is.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Hush
« Reply #157 on: May 14, 2010, 11:40:29 PM »
More likely your adjuster slipped enough to let the chain do that, never have been that keen on the stock cam chain adjuster, one little nut on a thread seems under engineered.
Jaffa's Suzi 400 has a cam chain adjuster so big you have to remove the starter motor to get it out, I know cos I had it off so often I actually made special tools to make it easier.
Good luck with the rebuild Scunny. :)
Offline scunny
« Reply #158 on: May 22, 2010, 06:43:23 PM »
650 has taken a backseat in the build sequence, I've got 3 bikes in bits and bench space is a bit crammed. will finish the 250 first.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Hush
« Reply #159 on: May 25, 2010, 12:19:08 AM »
Good Kiwi logic. ;)
Offline manjisann
« Reply #160 on: May 25, 2010, 08:19:13 AM »
Sounds like you already have the parts you need, glad to hear that, and hope everything goes well for you!!
I'm gonna be stripping one of these engines down soon, would you mind taking pics while you do this?
Anyhow, good luck!
Brandon
1980 CB650 Custom
Offline scunny
« Reply #161 on: June 16, 2010, 08:23:28 PM »
will take photos but they are pretty simple. removed the pistons today(makes mok ups easier) so I can put the top end back together and try to figure out what happened. the cam chain appears to be looser on the cam sprocket than an old set I have lying around. did my new chain go poop, will think this thru otherwise the motor has to be split and new chain put on........
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Hush
« Reply #162 on: June 17, 2010, 12:50:44 AM »
Ouch, our 650 cam chains are one piece eh Larry!
Offline scunny
« Reply #163 on: June 17, 2010, 02:04:38 PM »
DSS lists a "soft link" cam chain joiner. I might order a couple and have a play. I am unhappy how much the links can be lifted off the sprocket.
some thinking required.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Hush
« Reply #164 on: June 17, 2010, 10:49:13 PM »
Sounds like your adjuster mechanism has reached the end of its' adjustability.
Offline scunny
« Reply #165 on: June 18, 2010, 07:39:14 PM »
removed oil pan, dumped the bike on it's side and lo and behold the cam chain adjuster is not seated in it's pocket. this may also have happened when I rebuilt the motor, more thinking required.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Hush
« Reply #166 on: June 19, 2010, 12:39:38 AM »
Ah I suspected as much mate, I've got to say that after working on a lot of different makes of bike over the years that the 650 has one of the flimsiest looking cam chain adjusters I have ever seen.
The one on my partner's GSX400 is about the size of our starter motors and her bike is only a twin!
Offline scunny
« Reply #167 on: June 23, 2010, 07:31:03 PM »
still waiting for my new cam chain and soft links, so decided the bent valve better be replaced now, luckily it turns out the bend was right at the head, not along the stem so the valve guide is good to go.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Rich361
« Reply #168 on: June 23, 2010, 07:51:22 PM »
Hey Scunny,
Sorry to hear about your bike mate!!!
I don't know if you have heard about this website.... http://www.plenternz.com/
I found it while searching for front brake for my bike... Ha Ha yes still looking, wondering what to do??....
They sell OEM Parts and the great thing is it's in Lyttelton, Christchurch!!!
They seem a little bit expensive but when you consider you don't need to apply shipping costs etc to it.... probably not too bad...
Cheers
Rich
1975 CB400F
Offline scunny
« Reply #169 on: June 23, 2010, 08:12:56 PM »
cheers for that Rich, never heard of them before, and more than one supplier is good. no problems on the shipping costs, DSS love me.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline scunny
« Reply #170 on: June 23, 2010, 08:16:39 PM »
no worries on the bike. if they are gonna go, in the driveway is the place to do it. she was coming apart to redo brakes and suspension anyway but tried to jump the que, I'll never get my 400cc twin flat tracker going at this rate.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline scunny
« Reply #171 on: July 07, 2010, 06:58:21 PM »
bloody winter. have experimented with the soft link idea and the jury is still out. might just split the motor anyway but not today, I'll have to tidy the bench enough to fit a complete tear down.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Hush
« Reply #172 on: July 09, 2010, 12:05:28 AM »
That sux mate but with the winter well and truly here there aint many good riding days anyway.
I'm hoping to get a ride in this weekend, the rain has finally stopped after a solid week.
Offline scunny
« Reply #173 on: July 24, 2010, 06:18:02 PM »
ah well, got another 250 motor buttoned up now back to the 650.
split and rejoined the new cam chain, no problems there.
now back together we go. for the 650 owners out there, fitting the rings and holding the block isn't easy, we don't have studs to control things. solution is some 8mm threaded rod cut to 200mm lengths.
« Last Edit: March 28, 2013, 12:45:10 PM by scunny »
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline manjisann
« Reply #174 on: July 24, 2010, 07:28:49 PM »
Good to see you are making progress and thanks for the tip on the threaded rod. I just found a hole in my upper and lower case, think I must have thrown a bearing or something  :'(  so I'm looking at a complete rebuild on that engine once I've sourced some cases. Got pics of the carnage on my thread if you'd like to see em.
Brandon
1980 CB650 Custom
