Author Topic: Kickstart shaft retaining pin  (Read 3768 times)
Offline scondon
  • Mmmm......tasty bugs
« on: August 07, 2008, 10:09:49 AM »
    Does anyone have a successful method for removing the roll pin that retains the kickstart shaft on the 750's?   I need to inspect the shaft and gears but can't until I can get this pin out. Am afraid of mangling or breaking the protruding end by trying just pliers or vice grips. Thanks.
Re: Kickstart shaft retaining pin
« Reply #1 on: August 07, 2008, 10:20:04 AM »
Coincidentally, I just took one out on my spare engine I stripped (bound for the next project FreeBird II)  After much consternation, I gripped it gently? with vice grips, closing the gap in the pin a little bit, then tapped the vicegrips upward and the dang thing moved up. I repositioned the grips so as to close the gap a bit more, tapped it again and it moved up more. Rinse and repeat. It was out quickly.
Good luck.
« Last Edit: August 07, 2008, 10:23:30 AM by MCRider1 »
Offline scondon
« Reply #2 on: August 07, 2008, 11:49:03 AM »
 Excellent advice. Thanks :) :)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #3 on: August 07, 2008, 12:20:11 PM »
i've also used some large channel lock pliers, gripping and slightly twisting as you pull up. i posted a thread with the same question a little while back, having one that just would not come out. i had to lube it for a week, heat the case, and pull with a vice grip while prying beneath it with a flathead screwdriver.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #4 on: August 07, 2008, 12:26:07 PM »
All good advice. Soaking, heating, twisting and prying likely all preferable to tapping.
Ultimately, I was surprised how easily mine came out, after having agonized on how to do it for quite some time.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #5 on: August 07, 2008, 02:56:38 PM »
Good luck.
+1
« Reply #6 on: August 07, 2008, 06:03:42 PM »
Here tis: http://forums.sohc4.net/index.php?topic=29496.0
Grabbing it with sidecuts and levering it out sounds fair.
Offline rbmgf7
  • 2>4
« Reply #7 on: August 07, 2008, 07:14:20 PM »
vise grips and twisting motion.
it's just a spring pin. you can find them at Napa.
Offline Kevin D
  • SE Michigan
« Reply #8 on: August 07, 2008, 08:18:38 PM »
I took mine out with the sidecutters by levering it.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: August 07, 2008, 09:56:17 PM »
That's exactly how I did mine, Kevin.  I've pulled three of them this way recently, and in fact this is the ONLY way I've been able to get them out, vice grips were a no-go for me, but this got them right out.
I was more worried about buggering the aluminum boss that the pin sits in rather than the pin itself, but I had no issues with that.
mystic_1
- John Augustus Shedd
