Author Topic: Do I need a float level gauge/where to get one..  (Read 10962 times)
Offline zoo mob
« on: August 07, 2008, 10:42:18 AM »
Do you guys keep float level gauges as part of your tool kits? A friend says you can just do it by eye. Where is a good source?
Thanks
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline heffay
Re: Do I need a float level gauge/where to get one..
« Reply #1 on: August 07, 2008, 10:46:46 AM »
it can also be done by using a piece of tubing attached to the drain and held up against the carb body... fuel in carb and let drain.  will flow inside clear tubing to the exact level that it is at inside the bowl.
problem w/ this method is the requirement to disassemble, assemble, fill, set up tube, drain, measure, repeat entire process as needed!
all w/ only 2 hands!  and 4 carbs!
750fromhell
« Reply #2 on: August 07, 2008, 10:51:41 AM »
This is what this guy is using in place of the honda "special tool":
And how he measures 26mm. Is that what you are looking for?
http://www.salocal.com/sohc/tech/carb/asmpg_mgs/flthgt.htm
Offline feliz
« Reply #3 on: August 07, 2008, 10:56:13 AM »
If you're willing to shell out the bucks you can still buy the Honda tool from any dealer.
feliz
Current bikes:
05 Ural Patrol
CB750K1, K3, K4
08 Aprilia Shiver
Offline medic09
« Reply #4 on: August 07, 2008, 10:56:32 AM »
750fromhell has the right tool!  Any tool store has 'em.
Or, you can spend about 30-40 bucks for the 'real thing'.  I happen to have one... ::)
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline heffay
« Reply #5 on: August 07, 2008, 11:03:25 AM »
show off   :P
Offline zoo mob
« Reply #6 on: August 07, 2008, 11:07:47 AM »
I like the look of the oem tool, anyone have a part#? The last woman I spoke with at my local Honda dealer did not know whether a CB750 was a motorcycle or "something else"
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Offline heffay
« Reply #7 on: August 07, 2008, 11:16:10 AM »
maybe a little bit too local.   ;D
Offline zoo mob
« Reply #8 on: August 07, 2008, 11:48:09 AM »
Talked to the previously mentioned dealer, and they said they checked with their service department, and it would cost "over $100" Not happening.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Offline kghost
« Reply #9 on: August 07, 2008, 11:58:50 AM »
Both your friend and your dealer are idiots.
Seriously tho....you can make one out of a scrap piece of tin or aluminium.
Stranger in a strange land
Offline bozo4onion
« Reply #10 on: August 07, 2008, 12:18:01 PM »
1. Look at the gauge Honda sells. 2. Look at your disassembled carb. 3. Use your imagination. You don't need an adjustable one. I made one from stiff posterboard. It took 3 tries to get it right but in 15min. I was setting my floats. Worked perfect. Good luck.
Offline medic09
« Reply #11 on: August 07, 2008, 12:48:07 PM »
Buy one of those cheap rulers in the thread.  They're cheap, and you'll use it for many occasions.  I have two or three around the house.
Mordechai
'78 CB750K
Santa Fe, NM
Offline mkramer1121
« Reply #12 on: August 07, 2008, 12:53:03 PM »
check this thread and make your own:
http://forums.sohc4.net/index.php?topic=25423.0
Offline feliz
« Reply #13 on: August 07, 2008, 04:36:22 PM »
Not suggesting anyone buy one but to answer the question the part number is 07401-0010000 and I paid $38.02 in Canada so for sure it would be less in the US, everything else is. This was about a month ago.
I bought it along with a new exhaust for my K3 and we all know what they cost so the gauge didn't seem like much at the time.
feliz
Current bikes:
05 Ural Patrol
CB750K1, K3, K4
08 Aprilia Shiver
Offline timdhawk
  • 1978 CB750K
« Reply #14 on: August 07, 2008, 05:05:33 PM »
ebay has a few new for 35.00.
In deeper than I should be...
anhedonian
« Reply #15 on: August 08, 2008, 06:33:53 AM »
a paperclip bent snug around the ruler might suffice?
Offline immortal
    • 1976 CB750F "Pegasus bike"
« Reply #16 on: February 18, 2012, 10:12:11 AM »
Cut one out of an old plastic bucket lid, those laundry detergent lids are great, flexible and easy to cut out. I have made a few little tools and things out of plastic lids. Kghost is right, it only takes 10 minutes to make one then keep it in your tool box and use it over and over again.
Sometimes...the hard thing and the right thing are the same thing!
1976 CB750F "Pegasus Bike"
http://forums.sohc4.net/index.php?topic=80492.0
nomad
« Reply #17 on: February 18, 2012, 11:48:51 AM »
« Reply #18 on: February 18, 2012, 02:03:59 PM »
I cut mine out of piece of kydex because i had some in my shop but anything will do.  Precision down to .3 mm is enough.
« Reply #19 on: February 18, 2012, 09:48:12 PM »
Andy or Zoo Mob has not been active I see since  OCT of 2011 but is doing well in a job in Muskegon, Mi and last word was happy driving a big vintage Suzuki 4 and probably still workin' on his K0. You out there Andy  ;)    Eric in Kazoo
Offline crazypj
  • I'm brill, me
« Reply #20 on: February 18, 2012, 10:02:34 PM »
K&L Supply Company list an adjustable fuel level gauge
Any shop that deals with K&L can get you one
Given the choice, I've always used a wide steel rule
« Reply #21 on: February 18, 2012, 10:07:54 PM »
Yep
Offline grumpy
  • ..... '73 750K3 .....
« Reply #22 on: February 18, 2012, 11:11:29 PM »
I like the clear-hose-out-the-drain method.
It's the only way to really know whether the bowls are filling evenly.
Offline immortal
« Reply #23 on: February 19, 2012, 12:13:33 AM »
How do you do the "clear-hose-out-the-drain method" ?
« Reply #24 on: February 19, 2012, 12:31:33 AM »
on the pd type carbs you just lift the drain hoses vertical(if they are clear)and crack the screw,itll fill up to the level they are set to and show any imbalance,,the type ones you have to remove the drain screw dumping the bowls fuel and fit tubes and do the same thing.
