Author Topic: Do I need a float level gauge/where to get one..  (Read 12288 times)
Offline Johnie
Re: Do I need a float level gauge/where to get one..
« Reply #25 on: February 19, 2012, 07:01:10 AM »
Here are a couple home made ones. The one on the right is made from an old floppy disc.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline grcamna2
« Reply #26 on: February 19, 2012, 07:37:24 AM »
K&L Supply Company list an adjustable fuel level gauge
Any shop that deals with K&L can get you one
Given the choice, I've always used a wide steel rule
+1 0n the K&L Gauge..it's very adjustable and was good quality when I got mine in 92'...$32; I modified mine so it will slide over the outer flange raised portion of the carb. body and make direct contact with the gasket surface(after having removed the gasket to get the most accurate measurement)..;I took a hacksaw and cut a slot on each side.
« Last Edit: February 19, 2012, 03:21:25 PM by grcamna2 »
75' CB400F/'bunch o' parts'
bollingball
« Reply #27 on: February 19, 2012, 08:44:31 AM »
Immortal Here is a photo of the clear tube method and a cheap and easy test stand. Every thing can be set up and tested on the bench. Keep in mind this is for the 78 pd carbs.On earlier models the drain/overflow is a little different. If you look close you can see the fuel level on the #4 carb. It should be 2 to 3 mm below the gasket.
Click to enlarge picture Hope this helps.
                                     Ken
« Last Edit: February 19, 2012, 09:02:12 AM by bollingball »
Offline grumpy
  • ..... '73 750K3 .....
« Reply #28 on: February 19, 2012, 09:19:36 AM »
it's basically a spirit level.
attach clear fuel line to the drain plug & bend it up parallel to the side of the bowl.
the height of the fuel in the line = the height of the fuel in the bowl.
this method eliminates confounds like unevenly bent float armatures, differences in float buoyancy,  blobs of JB weld in the bowl, solar flares, etc.
« Last Edit: February 19, 2012, 09:26:47 AM by grumpy »
Offline immortal
    • 1976 CB750F "Pegasus bike"
« Reply #29 on: February 19, 2012, 10:53:19 AM »
Brilliant!...love it!
Sometimes...the hard thing and the right thing are the same thing!
1976 CB750F "Pegasus Bike"
http://forums.sohc4.net/index.php?topic=80492.0
Offline Really?
« Reply #30 on: February 19, 2012, 12:42:31 PM »
I used the pocket slide rule.  Not easy to find in a store to walk up to anymore.  People in the school supply store will look at you funny wondering what on earth you are talking about.  Too young to have ever seen revenge of the nerds I guess.  Using this, be sure to measure the height of both floats.  Don't think just because you do one that the it the same.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
