Author Topic: Any good sources for a rebuilt CB750 engine or someone who rebuilds them?  (Read 5994 times)
Depending on how brave I get, I may try to DIY, but I'd feel more confident getting a road ready rebuilt engine from a good source.  Can you recommend someone who rebuilds or sells used CB750 engines?
I'd rather not tempt fate and stick within a lower brain damage threshold by doing the other parts of my CB750 project.
Offline rbmgf7
  • 2>4
any decent engine shop or motorcycle dealership can rebuild one but don't be shocked once you hear how much it'll cost. labor alone is around $50/hour.
before you jump right into rebuilding, what's the situation on your current engine?
I just bought a 1970 frame, that came with a engine crank-case (without the upper half of the engine - cylinders, pistons, head, crankshaft, rockers, valvecover).  I can either search for more engine parts to make a Franken-engine, buy a used buy usable/rebuildable engine or buy a rebuilt.
Offline rbmgf7
  • 2>4
sounds like someone was wanting engine #'s to make a phony older model bike or restore their older model bike which was replaced with a newer engine.
you're best bet is to buy a complete engine and see what's up from there
Offline eastoak
boy, i sure wish labor was that cheap around here.........
For a strong running stocker.Hondaman..
Don,
Put yer friggin address in your info. Shipping one of these engines is damned expensive.
What's the 411 on Hondaman?  Does he rebuild engines?
« Last Edit: August 07, 2008, 11:12:18 PM by CB750 Cafe Racer Fan »
Offline markjenn
  • CB750K1, CBX, RC30
    • Whizmo and Gizmo
any decent engine shop or motorcycle dealership can rebuild one...
I guess this depends on your definition of "decent" but my experience is that VANISHINGLY FEW motorcycle dealerships or independent shops have the expertise and experience to properly rebuild a 35-year old CB750 engine - most won't even take on the work.  A generic engine shop that works on car engines?  No way.
When I had mine rebuilt, I did a lot of research and in the entire Seattle area there were basically two shops that came with a reputation for doing decent engine rebuild work on old bikes.  I interviewed them both and the guy I chose ran an independent shop that was well respected, had a CB750K0 in his office, and had rebuilt tens of them over the years.  It took a lot longer than planned and cost a bit more, but I'm happy with the work.
- Mark
Asimo
 :) I see from your address Orange County CA Red Hot Carpy "Steve Carpenter" is on your very doorstep What this bloke does not know about CB750 SOHC,s is not worth knowing about try Him first regards Asimo UK    P/S give my regards to Steve another good ex pat Brit! ;D
Asimo,
I definitely would like to get Carpy involved in one way or another on my project (even if it's just getting some parts or rebuild work).  I'm hoping he'll find my email amongst the many in his inbox when he gets back from Sturgis.
