Author Topic: Replacement rubber grommets for side covers  (Read 6190 times)
Offline rbmgf7
  • 2>4
« on: August 07, 2008, 07:46:48 pm »
was at lowes today cruising through there "specialty" bins. saw the rubber grommets and when "hmm" i wonder... on a hunch i bought the 1-1/8 OD x 5/8 ID, 3/8T grommet. cost about a buck so i got two just incase it didn't work. i replaced the upper grommet facing the front of the bike on my 78F. it's a little tight but the cover is definatelly NOT coming off.
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
Re: Replacement rubber grommets for side covers
« Reply #1 on: August 08, 2008, 01:39:51 pm »
Very sweet..
I've been thinking about how to do this myself. Because while I'm flying around my covers like to flopped around with the slack that the grommets have provided through there wear and tear..
Great find, I'm going to go try and find some tomorrow..
Since it's a tight fit, did you use some grease/lube to slide those nipples in there??
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: August 08, 2008, 07:48:23 pm »
Nice find.  Got pics?
mystic_1
- John Augustus Shedd
Offline rbmgf7
  • 2>4
« Reply #3 on: August 08, 2008, 09:31:42 pm »
i'm in KC right now so i'll post pics when i return home. i just travelled 200 miles and my covers are still there so that's a good sign.
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: August 09, 2008, 05:39:01 am »
Cool, enjoy the ride :)
mystic_1
Offline Raul CB750K1
« Reply #5 on: August 11, 2008, 03:09:41 am »
Honda still sells the original grommets.
Offline rbmgf7
  • 2>4
« Reply #6 on: August 11, 2008, 07:18:21 am »
i'm back. here's some pics
the one on the left is the oem grommet and the new one on the right
i've removed the cover a few times now and it still retains it's grasp. haven't figured out the size for the bottom one. i'll figure it out later
Offline tlbranth
« Reply #7 on: January 12, 2009, 09:00:54 pm »
One type of grommet on my goldwing is exactly the same as the side cover grommets on my 1970 CB750K0. Theyre tje 2 oval grommets in the picture.
http://www.wingstuff.com/pgroup_detail/14_Show_Chrome/3274_GL1500_GL1800_5_pc_Assorted_Grommet_Kit/
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline JAG
« Reply #8 on: January 13, 2009, 01:17:42 pm »
I I went ahead and found some in the bolts and nuts section at Lowe's, I could only find the size for the bottoms, and it worked out great. Although it may be a little too tight for my weak covers when it comes to ever having to pull them back off, I know atleast that they're not going anywhere.
Offline UnCrash
  • Pass
    • My Blog
« Reply #9 on: January 13, 2009, 01:40:36 pm »
Either they fall off or break apart when pulling them off....
I'm sticking with the stock part, overtight seems likely to have them crack when you're taking them off.  I've broken 2 this way while trying to be careful...
Offline rbmgf7
  • 2>4
« Reply #10 on: January 13, 2009, 03:52:29 pm »
i'm using LPM's repro covers which are about two times thicker then stock covers so i don't have to worry about cracking them
« Reply #11 on: January 14, 2009, 05:18:25 am »
I have a 78k and the covers are always very tight. I put a silicone grease on the tabs and the grommets so they will slide on and off easier.
Offline JAG
« Reply #12 on: January 15, 2009, 08:13:53 am »
You have a website for these guys??
Offline rbmgf7
  • 2>4
« Reply #13 on: January 16, 2009, 05:15:46 pm »
http://lpmreplicaparts.com/
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: January 21, 2009, 11:19:48 pm »
I just got off the fence and pulled the trigger on a pair of 750K0 side panels from these guys.  Will report when they arrive.
mystic_1
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #15 on: January 23, 2009, 07:22:20 am »
;D ;D ;D
im sorry
Offline JAG
« Reply #16 on: March 19, 2009, 09:18:01 am »
hahahaha, I knew when I wrote that, it wasn't going to sound too good...
